A/B boxes
Started by Narcosynthesis, June 30, 2004, 07:13:41 AM
Narcosynthesis
does anyone have a wiring diagram of an A/B box i could use, i had a few good ones but i lost them when i got a new computer...
David
Narcosynthesis
jsleep
For great Stompbox projects visit http://www.generalguitargadgets.com
Narcosynthesis
these are the two different ways i have found for making an a/b switch, the first i made from a looper diagram i butchered slightly (ie, getting rid of the return jack)
the second is the dod version just redrawn by me
so which would be the preferred version?
David
Russ
Go to fulltone.com, and look under "Tech Tips". Mike Fuller has a great diagram for a really good, simple A/B box which grounds the output of the channel not in use. FWIW, it's the same diagram Eric Johnson uses for the A/B boxes with which he channel-switches his amplifiers. I built a couple, and they work very well.
Hope that helps,
Russ
