Frequency Splitter ??
Started by loki, July 08, 2004, 11:45:09 AM
loki
Hi guys, lately i've been looking at some rigs of famous artists compiled at guitargeek.com... in a bassist's rig there was a pedal named "home made frequency splitter box", which basically sends only the frequencies you choose to its loop of effects. in this rig's case, the signal top end is sent to the big muff and to a vox wah which then affect only the high frequencies leaving the bottom unaltered.
since i'm curious about this kind of pedal, do you know if there's any schematic around? i reckon it shouldn't be much different in conception from the bass paraloppel, but that just blends the dry and wet signal, without splitting the frequencies.
thanks, bye
cd
Take a look at the Craig Anderton's Quadrafuzz:
http://www.paia.com/quadrafz.htm
Rich G.
Sounds like a crossover.
Check out some info at Rane
The AC-22 should get you started.
Athin
looks like a few [high/low/band-pass filters with seperate outputs.
DIY XOR die.
toneman
Other thoughts thunk while thinkin'...
"biamp"?
"triamp"?
or
EH "Equalizer Fuzz"
tb
niftydog
niftydog
Shrimp down the pants!!!
nosamiam
Maybe you're looking for this:
http://www.moosapotamus.com/paraloop/paraloop.htm
This is going to be my next project.
