Highway 89 build problem
Started by Alpha579, July 30, 2004, 05:58:41 PM
Alpha579
Hi all,
Ok, ive wired everything up, voltages are looking correct on the perfboard, and i cant see any bugs with wiring, but i only get sound out of the pedal when i touch the volume pot with my hand.  :? ???
anyone know why this is?
Thanx for any help,
Alex
Alex Fiddes
Paul Marossy
Are you sure that everything is connected to ground properly at the volume pot? Maybe you have a cold solder joint or something?  :?
Joe Davisson
Maybe one of the jacks is wired wrong or backward?
-Joe
Alpha579
Ok, i found i had a faulty volume pot, got it from dick smiths, all my pots from there fail :x . Ive replaced it with an alpha pot 1M, and now i get signal though, but it sounds horrible misbiased. Does anyone have any highway 89 voltage readings i could compare with?
Alex Fiddes
