Variable Caps
Started by jmusser, August 13, 2004, 08:30:55 PM
jmusser
I was wanting to know whether anyone had ever used variable caps on the inputs and outputs of fuzz circuits to tune the different bass and treble tones with it? I honestly don't know if there are caps to use for this purpose, besides the ones out of the tuner sections of radios. The only ones I know about are air dielectric. I was just curious, because I've never seen them in a circuit. It may not even be possible to use them. I was just sort of throwing the idea out there to see if it's been done.
Homer: "Mr. Burns, you're the richest man I know"            Mr. Burns: Yes Homer It's true... but I'd give it all up today, for a little more".
Mark F
I believe the only variable caps that would fit in a stompbox are in the low pF range.
nero1985
u can always use a rotary switch to get different caps or a pot to blend the signal betwee caps like a tube screamer
guitarhacknoise
hello
     http://www.newton.dep.anl.gov/newton/askasci/1995/eng/ENG62.HTM
       that's if you trust the feds.
 or,
      http://www.books4you.addr.com/VariableCapacitor.html
not really that wide of a range
"It'll never work."
Nasse
How about using mini dip switches and few different caps, used on some projects and commercial pedals
