ab box
Started by siaoguitar, September 14, 2004, 08:38:08 PM
siaoguitar
Hi to all, I've completed my first project, the AB box by Aron (battery snap replaced by dc jack) at FAQ page(amp/tuner)
but my only problem is
1) the hum when i connected the out to my guitar amp, is it because i have not mount the components in my enclosures?
2) Can i connect a battery snap to the wiring? Coz' i tried soldering a battery snap after the dc jack then the black wire of the battery snap to ground, the circuit didn't work, should i connect the battery snap directly to the switch?
Aron what's the difference between this and the true bypass box with led by you?
siaoguitar
How Aron? i still can't get my ab box to work, it still got this humming sound, and there are cracks/pops when i move the circuit around.
:-(, pls i really need this to work
siaoguitar
Aron btw, i am using battery snap now.
Paul Marossy
Are you sure that all your grounds are connected together?
aron
The cracks/snaps indicate bad solder connections. Please check your wires/solder points.
siaoguitar
ok, i shall check the soldering again
