If you can stay clear of the filter caps you won't have a problem. If you're worried about them, discharge them before you do anything else.
As for the lead itself. Make sure you replace it with a suitably specified cable; Some power cables are cheap and only designed to pass small currents. Ensure you redo any insulation over the terminals and properly refit any grommets or strain relief. But most importantly, make sure you wire it correctly!
