Digital Volume Control Voltage Reduction?
Started by Arn C., October 03, 2005, 10:24:33 AM
Arn C.
Howdy Folks!
      I am building a digital volume control using a DS1669, which I just received from Future Electric.
The input voltage calls for +5 to +8 vdc .   I have an ultra power supply I built that has 9volts output.  What value resistor and wattage should I use to reduce the 9 volts to 6 volts?
Thank you for your help!
Arn C.
Paul Perry (Frostwave)
I'm not sure that using just a resistor & cap will do, because the current (from a brief glance at the data sheet) seems to vary from practically zero to 2mA.
So I'd be thinking of a 6v zener, fed from a 1.0 K resistor.
Or use an adjustable regulator, set to 6V, you have enough headroom (but that would be overkill, I admit).
And check out the application notes on the Dallas website..
Arn C.
Arn C.
I ended up putting in an LM78L05.   I will test it out tonight at home to see how it works.  It is a digital volume pedal with 64 steps up and down.  I will still have my passive morley volume pedal inline set for max volume level that I want.  This way I can go up or down in volume incrementally, since I seem to have a problem raising and lowering volume slowly while playing.
Thanks folks for your help!
Peace!
Arn C.
A.S.P.
series-diodes can be used to drop volts...
(~0.7V per 1N4148; ~2V per LED...)
Analogue Signal Processing
Arn C.
Well, I tried it out and NADA, NOTHING, ZILCH, etc...
I will have to check it out tomorrow.  It may be my 9vdc power block connector, not matching up with the connector I put in the box.   so many could be this or that.  Back to the drawing board! :icon_sad:
Peace!
Arn C.
A.S.P.
how do you "control" (address) that chippy?
Arn C.
 :icon_confused:
I suspect by your reply I am leaving something 'important' out of this circuit, that I probably no nothing about. :icon_confused:
I can take it!
Peace!
Arn C.
Quote from: A.S.P. on October 03, 2005, 06:44:23 PM
http://www.maxim-ic.com/appnotes.cfm/appnote_number/168 reveals all.
You don't need a micro or anything, there is a "button" mode, where you just have an up & down button.
I thnk this is a perfect app for two 'reflection' sensing IR optical switches, but that's just me. I'm sure traditional stomp switches would be too clunky, though.
Arn C.
http://www.electronics-lab.com/projects/audio/033/
The above is what I used.  I guess I must be missing something.  That circuit is what I built and used 5voltsdc regulated with an LM78L05 and I get nothing.  I did miss where it said to use a dual polarity power supply to cure clipping problems(I didn't do this).
There must be more to this, but I don't know what it is.  I used two N.O. momentary stomp switches.
I'm Lost.............
Arn C.
A.S.P.
what`s the suffix # of your DS1669?
if it`s "10", and you hooked your guitar directly to it,
it is loaded by a parallell R of 10k...
Arn C.
Yes, it is "10".  So, does this mean that the signal is loaded down to the point where the signal won't go through?  If so, is there a remedy for this?
Arn C.
A.S.P.
not that nothing goes thru,
but that there`s nothing left right up front, to be divided down.
in this case you need a buffer in front of the digi-pot;
or hook the pot after your first pedal in the chain.
you can test the functioning of the pot itself, by hooking a cd-player or the like to it.
Arn C.
So, are you basically saying that I need the signal to be boosted before it goes into the digital volume pot box?
Arn C.
A.S.P.
not neccessarily boosted, but buffered
the status quo you got now,
is having the guitar going into a 10k pot...
(as opposed to 1M or 470k usual impedance of amps/FX)
Arn C.
So, if I build a small buffer circuit, I am sure there are some around here, and place that in the beginning of the audio signal then into the ds1669 chip, it should work?
Thanks a bunch for your help on this.
Arn C.
A.S.P.
Arn C.
Thanks A.S.P. for your help!  I will give it a try...
Arn C.
Arn C.
"IF" I get clicking when I depress either switch, how could I eliminate that?
I built the buffer from GGG, the transistor one.  I won't be able to try this until I get home this afternoon.
Thanks,
Arn C.
