Author Topic: Jordan Bosstone and Bossboost pictures  (Read 31715 times)
Re: Jordan Bosstone and Bossboost pictures
« Reply #40 on: March 14, 2019, 09:28:25 PM »
> Unsorted: 35 to 470
Low price. Specially in 1967.
The collector feedback greatly reduces bias variation. hFE=35-470 makes only 2.3:1 change of current.
Anyway, what's the worst can happen? It distorts. Isn't that what they were selling?
And as you note, some of these whole-hog bargain numbers were available dot-sorted.
« Reply #41 on: March 15, 2019, 01:09:43 AM »
To me the biasing can make it or break it.
I guess there's two angles: one is to make a representative clone, the other is to make it as good as it can be.   The last thing we want is to make clones that don't sound like the original or don't sound good!   That's how a lot of germanium fuzz clones end up.   At one point I made notes about vintage fuzzes from youtube videos and some of the worst and best were actually the same circuit!
« Last Edit: March 15, 2019, 02:59:25 AM by Rob Strand »
Plopping around the pot since An unexpected error has occurred.
« Reply #42 on: February 25, 2021, 12:46:56 AM »
Stuff found on my hard disk.
Code: [Select]
Boss Tone Info and Chrononology
Rob S, 2021/02/21
I've kept the common circuit numbering (1 to 5) from the web, but there's a bit more to it.
Also there's a difference between manufacturing build and the schematics alone.
All models are au-0606 until we get to the 6248 Sho-Sound
Alhambra (1967, 1968, maybe 1969)
Pasadena marked au-606 but has Nashville circuit
Features identifying versions:
- external labels
- pcb color and pcb number etched on solder-side
- transistor packages and location of transistor on boards.
- The California circuit puts the transistors on opposite corners of the PCB.
  and the Nashville put the transistors in the same corner.
- parts marked ***
Revision History:
- added info on Pasadena unit
- added info on PCB markings
- resolved some of the transistor markings
California 1 schematic V1.0
C2 should be 220p
The transistors have dots which indicate the hFE's; see details below.
Circuit 1
Schematic: California 1
Label: Alhambra Calif,   au-0606
PCB: IC-0193 B ; solder-side marking
PCB has a large square pad between the PCB number and mounting hole.
*** Diodes orientated across PCB;
Transistors:
2x2N3397 NPN, Package TO-98 skirt, orange dots
Orange dots => hFE=135, based on same process 2N2926
TO-98 is like a TO-92 with a round skirt at the bottom
Knobs: two different markings.
Circuit 2
Same design as Circuit 1 except different PCB
PCB: Likely IC-0193 C ; solder-side marking
*** Diode orientated along PCB
*** 100k orientated along PCB
(*** 33k & 470R loaded on PCB)
Transistors:
Both NPN, TO-92 but no dots.  I expect 2xMPS6513
Circuit 3
Schematic: California 2
PCB: IC-0193 C or D(?)
Ground hex post does not have a tinned area.
*** 100k (located near wires) mounted on an angle,
100k moved to mount Transistor in different holes,
red wire also moved.
Parts:
Links loaded in place of 33k & 470R.
Q1 feedback resistor 10MEG
Caps: 2x20n
Output cap: 20n
Feedback cap: 220p
Transistors:
Q1 2N3397 NPN, TO-98 skirt, yellow dot
Yellow dot => hFE=225, based on same process as 2N2926
Q2 Motorola MPS6513, NPN, TO-92, gold leads ; hFE = 90 to 180 @ 2mA, calc avg hFE = 135
Example: (Sir H C, 2006)
"California Bosstone, 2N3397 (yellow dot) and MMPS5513 (face down) vertical cap is 220k,
cap under other is .02 also, can not read diode values."
Note first M is the Motorola logo not the part number.
Circuit 4
Schematic: California 2 + cap mod
Same as circuit 3 except output cap is 470pF; Solar 470M Z5R.
The cap is thicker and is not stacked with the other caps in
the middle of the PCB.
Circuit 5 Nashville circuit with both transistors next to each other.
The upper transitor is the NPN and the one nearer the corner the PNP.
This have a number of sub variants.
Pasadena
Uses the "Nashville" circuit.
Has red white blue wires
Schematic: Nashville
Circuit: Nashville
Label:
Pasadena, South Pasadena California
PCB: Text "IC-0193 F"
Brown color on component-side
Dark green soldermask on solder-side
Parts: 100n input cap (Solar brand)
Others? (Solar brand)
2x 18k's
Transistors: Q1: Motorola SPSxxxx, NPN, TO-92, gold lead
Q2: ???, PNP, TO-92, gold lead
Diodes: 1N4001?, 1A rectifiers, Black, Motorola
Not fully Identified:
Similar to previous but different transistor packages.
Circuit: Nashville
Label: ?
PCB: Brown color on component-side
Parts: 10n input cap
Transistors Q1:  NPN, TO-106 button
Q2:  PNP, TO-92
Diodes: 1N4001
Not fully identified: (from a schematic)
Circuit: Nashville
Label: ?
PCB: ?
Parts: caps 2x18k, 3x10n
Transistors:
Q1: F70N1 1142812  (maybe E70N1), NPN; Probably F = fairchild
Q2: M852 95232, PNP ;implying M= motorola symbol 8 = 1968, 52 = wk52, part no. = 95232
A part source indicated: NTE159 = 2N3906 = 95232
Diode: 1N4001
Comments:
I have a suspicion the Fairchild part might be a TO-106 button head.
That would essentially be the same as next version with he 2N3565.
Nashville
Circuit: "Nashville" Circuit
Label SHO-Sound, Nashville
PCB: No PCB number.
PCB is light green semi-trasparent fibreglass
PCB tinned but with no soldermask.
Parts: (Sir HC unit)
3x10n
18k + 18k
Transistors:
Q1: 2N3565. NPN, TO-106 button package
Q2: Motorola 924 95232, PNP, TO-92
The M at the start of M924 is a Motorola Logo not the part number.
Likely to be date 1969 and part number 95232.
\E B C/  botton view, gold leads
Diode: GI (General Instrument)
look like 1A rectifiers.
Variants:
*** Caps seem to vary: 10n, 20n, 50n
Label: SHO-Sound, Nashville
PCB: ?
Parts:
RLBJR65 (Richard Boop)
« Reply #9 on: August 20, 2006, 11:05:42 PM »
"Interesting! I've also seen the Sho-Sound Nashville model with
3 - .05uF, 1 - 50pF, Q1 - MPS6513 and Q2 - 2N4249, unreadable diodes, ..."
Q2: 2N4249 hFE = 100 to 300, PNP, Silicon
Comment on this:
MPS6513  NPN is a TO-92 package, and the PNP 2N4249 is a TO-106 button.
This swaps the position of the TO-92 and TO-106 compared to previous versions.
One example of a board with this build had a blue component-side PCB.
I can only assume these are later manufacturing runs.
Transistor packages:
TO-92 common flat-face plastic package
TO-98 like a TO-92 with a round skirt at the bottom
TO-106 Small button head
Bias points
For ckt1,    calc Q1 at VC1=3.4V
For ckt3,4,    calc Q1 at VC1=3.2V
For ckt1, 3, 4 calc Q2 at VC2=3.05V
For the Nashville circuit, VC1=5.3V, VE2=5.9V
« Last Edit: February 25, 2021, 05:22:55 PM by Rob Strand »
allesz
« Reply #43 on: February 26, 2021, 03:29:27 AM »
Interesting tread!
I do love the bosstone topology; I like the California version with bigger caps (22 to 47 nF) and no clipping diodes. Also I like to mix Si for q1 and Ge for q2.
Always been curious about the boss boost, there are not schematics on line, nor videos on YT or reviews... He said with sweaty hands :-)
