Took about 3 hours,including the board etch........not bad considering that ended up being a really good sounding fuzz.
Got the PCB from Fuzz Central and proceded to find suitable transistors from my stash of old pulls.
I had a fistfull of 5117 and 5115 left over from my wha build so I started measuring hfe till i found about 5 that could be used and found one metal can BC108,that measured 140......
SO ended up with a 5115 as Q1 (hfe 70) and the BC108(hfe 140).
Sounds really warm and not harsh at all,for the SMOOTH control I used a trim figuring that I would set it to where I like it and leave it there just cause I wanted to preserve the 2 knob arrangement of the classic FF,might as well,left it at full.
Used a 22uF for the fuzz control instead of the 15 and a 0.033uF instead of the 0.047.Input cap is a 0.22 and set the bias by ear but will do it when I stop playing with it.
Really chewy fuzz and nothing to envy any of the other germanium fuzzes I've heard or built,lots of sustain without loosing dynamics.........all the good stuff.
There's no gating at any bias point.
Keeper!!!!!!!!!!!
The 5115/17 pinout is ECB flat side facing you ,just in case somebody needs it.
Take care and thanks
Aharon
