Seems wired right enough, 2k2 from ground to gainpot and 22n and top switch lug, middle switch lug to white primary transformer wire, bottom switch lug to ground. Easy to see, checked it three times.
Did I miss something? With the gainpot above 9.5 I get attenuated octave sound, all settings below 9 produce clicking, kind of like an LFO tick, med/fast speed, small speed change w/gain adjust.
This one turned out great tho, Excellent Octave effect works wonders with Fuzz or Boost or.
And it fired right up the first try !! Replacing two other octaves that couldn't keep octaving [for some strange reasons the Tycho and GR both went kaput in that PB position]. I don't feel such a strong need to debug either of them now, because Bob's doing a fine job there, very similar but 'purer' [than my T.O. or G.R. used to be] when driven to Purple Haze Fuzz induced nastiness. Does lots of ringer-ey wierd stuff too ! Kind of weak without a Fuzz in front or behind it, or a boost in front, just the way I like it !
I'm just trying to figure out what the Spinal Tap mod is supposed to sound like.
