Author Topic: 4. Off-Board Connections and Clipping Diodes  (Read 30124 times)
gaussmarkov
« on: May 29, 2007, 10:54:52 PM »
final step!   :icon_biggrin:   Off-Board Connections
i hope you enjoy this.  with best wishes, paul
gaussmarkov.net:  layouts & eagle
gaussmarkov
JasonG
Re: 4. Off-Board Connections and Clipping Diodes
« Reply #2 on: June 15, 2007, 11:22:14 PM »
Did you mean to say that the 5th cap goes to j 28 to j31 insted of  J26 and the other in J28?
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
gaussmarkov
« Reply #3 on: June 15, 2007, 11:38:44 PM »
good catch!  i meant to say J29 to J31   :icon_wink:  thanks, bro!  :icon_biggrin:
EDIT:  ok, fixed it.
« Last Edit: June 15, 2007, 11:43:37 PM by gaussmarkov »
JasonG
« Reply #4 on: June 16, 2007, 08:12:24 AM »
Thanks for correcting my mistaken correction of your mistake. :P
Styxx
« Reply #5 on: December 05, 2007, 02:04:22 PM »
I'm doing a uni project on a distortion/overdrive pedal (Something like Visual Sounds' "Jekyll & Hyde") and this looks like just what I need! I've only had a 10 minute skim over the four sections, but you've managed to simplify to a level I can actually understand! :icon_lol: Thanks :)
frankclarke
« Reply #6 on: December 05, 2007, 03:18:49 PM »
Looks good thanks. You can use that as a stripboad layout if you cut a line of holes across the stripboad. Not optimal, but at least it will work the same as the breadboard.
gaussmarkov
« Reply #7 on: December 05, 2007, 04:40:35 PM »
cool.  :icon_cool:   :icon_biggrin:
fwiw, in this thread [Vero?] i through together a sketch of an actual stripboard layout.
all the best, gm
« Reply #8 on: August 17, 2008, 12:07:57 PM »
I did it :D.... finally...
Here in my town there aren't any big stores... only small, old-fashioned electronic stores, and I had to go to all of them to find the pieces....
And since I was a little disappointed on how the beginner's project worked for me, I wasn't really sure how this was going to come up.
But I finally finished It, it sounds great, thanks to all the people that posts here  :icon_biggrin:
gaussmarkov
« Reply #9 on: August 17, 2008, 12:12:38 PM »
excellent!  that is great news.  :icon_cool:
demonstar
« Reply #10 on: August 17, 2008, 12:24:06 PM »
Glad to here it Carlos, good stuff!
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
Johnnie D.
« Reply #11 on: May 05, 2009, 02:40:05 PM »
This is excellent!
This is the only article I've read that actually explains the parts, their function and their relationship to one another.
I found a breadboard on the net and I'm waiting to try the things you have shown me.
It will be great to try things before soldering them.
Thank you!
samokunzo
« Reply #12 on: June 08, 2011, 03:25:36 PM »
Thank you very much GM!
Guitarist335
« Reply #13 on: July 11, 2020, 09:51:24 PM »
Thank-you for this great tutorial.
I methodically put it together on the breadboard, following your instructions.
When I tested it without the diodes, it worked and I heard distortion. After I added the diodes, it also worked and I heard distortion.
But then suddenly, it went back to simply hearing a clean sound. Any ideas what coud have caused this?
Questions:  1
I am thinking that perhaps it was a breadboard connection thing. i don't cut the legs from my resistors and capacitors, and thus they often dangle on the breadboard. I wonder if something like that a happened?
Question 2:
I also wonder what kind of capacitors are being used here. is there any way to specify whether a film electrolytic or ceramic capacitor is being used? Maybe that also caused my problem- choosing the wrong capacitor type?
Question 3. Is there a chance I blew the op amp? How would I know?
Thank-you for your help and expertise.
« Last Edit: July 11, 2020, 09:57:25 PM by Guitarist335 »
11-90-an
  • Great Contributor!
  • Total likes: 136
  • (Put my username into the periodic table) - PH
« Reply #14 on: July 28, 2020, 08:02:44 PM »
Have you tried whacking your breadboard?  :icon_mrgreen: :icon_lol:
Cap types shouldn’t matter, as long as the values are correct, power ratings not lower than your PSU (which should be 9v) and as long as you get the polarity of electrolytics correct, otherwise they heat up and explode.
If you swap the op-amp and it works, then that’s it... otherwise get some voltages... :icon_biggrin:
Happy Sawdering!
