TECH21 Sansamp BassDriver DI (or something like that) *SCHEM*
Started by Shakal, July 22, 2007, 10:23:25 PM
Kornell
Mine it's working.  :D I'm using the gt2 tonepad pcb beacuse they are very similar."Just" needs to add and extra board to get the blending part.
Now it's time to mod!!!  ;D
12afael
can you make some test around the blend pot?
I regret to say that I have not had time to find a cure for the problem of the blend, at this moment a friend is testing the pedal so I do not have it here to test it.
I suspect a resistor between the first op amp output to the blend pot could make the trick.
my last board have a little issue on SW3. I want to update it with a final solution to the blend problem.
Kornell
Quote from: 12afael on November 15, 2007, 09:33:57 PM
- No problem with the blend pot but I've got some ic voltage values I don't like.
- Following your pcb would be  pins 5&6 from IC1 that vary from 3.8-5 if I change the drive pot.  :o
- The rest of the voltages look OK.
So when you get your sansamp back please measure those voltage to compare. Thanks!.
12afael
mmm I will try to check that. it must be a issue with the load because the drive pot is one stage after the ic1b.
feedback should make the input impedance bigger , if it is changing too much could be part of the problem.
I will try to check it.
Kornell
- I've measured those values on my behringer clone of the bassdriver and has similar values. So I supose that's the way it is.  ???
- It sounds  good and that's what matters,no?  :D
- Before trying a proper mids control I'm going to replace the 100k and 22k that controls the two mid-notchs. I don't want to end with 8 pots, too much to drill... :icon_mrgreen:
12afael
any chance of have pictures of the guts of the behringer clone?
Kornell
It includes true bypass, mids control and a new blend control.
Ugly Inside:  ;D
http://img510.imageshack.us/img510/7160/dscf0378ek5.jpg
Outside:
http://img258.imageshack.us/img258/3705/dscf0377vj3.jpg
If you want more inside pictures just tell me.
O
Was this project ever verified? I'm getting all the parts for it, but I want to make sure its going to work before I start.
Kornell
Quote from: O on January 09, 2008, 09:47:48 PM
- The schem is correct, except maybe  a capacitor between the clean-buffered signal and the lug of the blend pot. It works without that capacitor.
- You can use the PCB that posted 12afael, that I believe it's been verified.
- Or you can adapt the sansamp GT-2 board as I did. Just need an extra board to include the blend function. I'll ask F.Peña permission to publish the modified board and schem.
Later I'll post some clip.  ;)
O
Kornell
Quick and short clip: http://boomp3.com/m/b387fec9406e
Clock settings: Presence: 1:00 Drive: from 1:00 to 5:00 Blend 5:00 Bass&Treble 11:00
Mine is not the stock version because I feel it lacks some mids and has too much bass.
If you search on  the www there's lots of  clips using the original version.
O
Cool clip!
I think I know what I'll be building this weekend :D
alejandro69
I build it, seems to sound good but have a question about the volume. Looking with an oscilloscope with drive = 0 and level=10 the output signal is like the input signal in amplitude (no amplification) is that correct?
When I add drive the volume increase. Regards
DimebuGG
Is build this weeks ago using the schematic traced by DIZ(rectangular ear bass 21). 5 dual opamps except the DI circuit. I'm not sure if the schematic is correct though but anyway this schematic has a punch after all!!I mean after building it and tested it
O
Quote from: DimebuGG on February 15, 2008, 05:46:41 AM
Any pics? :D
DimebuGG
It's just the GT-2 PCB and then modified. the 5th op amp is offboard.
I'll try to post pics.
DimebuGG
to anyone who wants to build 12afael's layout:
Lift off  R47 and R48...."+" side of C20 faces R25 and remove the other 2.2uF cap(C21) then put a jumper on it.
Remove C17( connected to CW of BLEND pot) also and install a jumper.
O
Quote from: DimebuGG on February 18, 2008, 12:32:46 PM
Does this fix the "blend cutting off" issue?
9re9
Sould I use linear or log for pots? Sorry for the stupid question...noob to the DIY world
DimebuGG
Quote from: 9re9 on March 18, 2008, 12:53:22 PM
Just use linear ones but if it doesn't suffice your taste then use audio tapered. Anyway i'm using 100K linear pots.
