Author Topic: AMZ Mini-Booster completed(in 1 hour!) on perf  (Read 5988 times)
RDV
« on: August 20, 2003, 09:13:18 PM »
Great booster Jack! Really nice! I left out the 10uf cap. Does anyone like it better left in?
Also; I used a 2.2uf NP instead of 3.3, but it still seems to have plenty of low-end. This is a box-bound circuit for sure!
Regards
RDV
Jered
« Reply #1 on: August 21, 2003, 02:23:54 AM »
Hi Ricky, try a hi quality .1 uF film cap in place of the 2.2 uF and then add the 10 uF and see what you think. What value source resistor are you using, 100 ohm, 1k?  MB is still one of my favorite building blocks.
   Jered
RDV
« Reply #2 on: August 21, 2003, 07:19:25 AM »
I'm using the 1k. Is there a difference :?:
Regards
RDV
Jered
« Reply #3 on: August 21, 2003, 08:32:48 AM »
  Yes, big difference. Lower resistance = more gain, and adding the by pass cap adds even more gain. You can put a 5k or 10k pot in place of the source resistor and hear what I'm talking about or just use it as a gain control.
    Jered
RDV
« Reply #4 on: August 21, 2003, 09:00:01 AM »
If you do both the pot and the cap, do you end up making it more of an overdrive by making the first JFet drive the second into distortion :?:
Regards
RDV
Jay Doyle
  • Guest
« Reply #5 on: August 21, 2003, 09:22:14 AM »
RDV,
Look here:
http://www.geofex.com/Article_Folders/modmuamp/modmuamp.htm
It explains a lot and gives you some options to mod.
Jay
RDV
« Reply #6 on: August 21, 2003, 09:46:46 AM »
Has anyone tried the 1K resistor between the source of the upper JFET and the drain of the lower JFET mod that R.G. talks about :?:
Regards
RDV
