Photosensitized boards
Started by Mike Nichting, September 21, 2003, 01:34:50 PM
Mike Nichting
What exactly are Photosensitized boards and are they OK to use for effects building??
What is DFD type developer??
mike
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
smallbearelec
Mike--
This type of board is coated with a photo resist. Typically, you print your pattern in black on a clear transparency film (as a positive of the image), and expose the board through this mask in a photographic contact printer or similar jig. Then you "develop" the board in an alkaline solution to remove the exposed resist, and then etch as usual in Ferric Chloride.
If you do it right, the photo process produces very fine line widths accurately. But there are some disadvantages to it: Especially, you really need perfect contact between the positive and the board, or you get scuzzy traces.
Regards
SD
Mike Nichting
Thanks Steve~!!
I think I;ll stick to your P"N"P sheets :-)
Mike
