Author Topic: Vibracaster - or "How to turn your Valvecaster into a Tremolo"  (Read 149289 times)
MikeH
Re: Vibracaster - or "How to turn your Valvecaster into a Tremolo"
« Reply #20 on: August 19, 2008, 10:37:41 AM »
Looks awesome!  I'm going to make a little add-on board and make this a switchable mod.  Looks cool.  Does it behave the same @ 12v vs 9v?
  • Poster2
  • Total likes: 113
  • Virtue signalling keyboard warrior since 2020
    • frequencycentral
« Reply #21 on: August 19, 2008, 10:42:56 AM »
I breadboarded the oscillator at 9 volts, It seems to work the same at 12 volts. Tubes circuits definately work better at higher voltages!
Equal to you, just more so.
Questo Ŕ il fiore del partigiano morto per la libertÓ!
Salvatore
« Reply #22 on: August 19, 2008, 10:47:01 AM »
Yeah, I'm planning to make the 5672 VCA too - you should translate the whole thing for me - the only Dutch I know is "Let Op! Drempels!"
Well, at least you know some relevant Dutch, "watch out ! Thresholds". :icon_lol:
If you want I could translate the interesting bits, that would not be to much work.
But I could not start until at least a week from now, bit busy at the moment with a new band.
jacobyjd
« Reply #23 on: August 19, 2008, 10:48:41 AM »
I may have missed it above, but I know most are running their Valvecasters at 12v (or higher)--would 12v be too much for running this add-on?
heh, never mind :)  Too fast for me!  :icon_neutral:
Jimmy-H
« Reply #24 on: August 19, 2008, 01:37:37 PM »
Build this one Jimmy, the Bipolar Disorder is a lot more pain for not much more gain. The BD took ages to iron out problems with, LFO bleed and thump, the Vibracaster just worked well first time. Also, the parts count for the Vibracaster is just tiny in comparison with the BD.
OK Rick, I'll keep that in mind.
By the way, I just listened to your recording of the pedal, sounds great!
Keep up doin' the good work  ;)
nokaster
« Reply #25 on: August 19, 2008, 02:18:18 PM »
"Let Op! Drempels!"
being belgian... this was a very funny read!
weird which phrases end up as the only one someone knows in a certain language!
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #26 on: August 21, 2008, 01:41:07 PM »
Here's a schematic for the Vibracaster with pinouts and heater circuit if you want to use a 6111 submini tube instead of a 12AU7:
Fl!P
« Reply #27 on: August 21, 2008, 03:34:13 PM »
Well done!
But, uh... Excuse me for asking, but can I get some sound clips?
 ;D
Completed Builds: Gus Booster, Plexizer, BSIABII, Si/Ge Fuzz Face w/ RM Mod, Orange Squeezer
To Do List: Valvecaster, Small Clone, Jawari
For Sale:Marshall Footswitch
Renegadrian
SOUND CLIPS
« Reply #28 on: August 21, 2008, 03:43:01 PM »
Fl!P
comfortably_numb
« Reply #30 on: August 21, 2008, 05:18:13 PM »
I'd like to take the opportunity to point out that the 12AU7 heaters can be run in parallel at 6.3 volts as well, and so any of these circuits can be safely used at 9V with the heaters in parallel following frequencycentral's voltage drop technique.  The 12U7 data sheet does not specify a parallel heater voltage, but as there is a center tap (pin 9) I imagine it would function similarly.
Renegadrian
« Reply #31 on: August 21, 2008, 05:53:03 PM »
yeah, I remember it was discussed in the main valvecaster topic...the way you can use pin 9  and what it's for...
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #32 on: August 21, 2008, 06:05:25 PM »
Might need a recalculation for the series resistor value @ 9 volts though.  :icon_wink:
Renegadrian
Vibracaster
« Reply #33 on: August 26, 2008, 03:29:35 AM »
Hey Rick, I have some BC 548, both B and C - would they fit? Or should I stick to the 547s you used???
Also, why did you use a 100k LIN and not LOG for VOLUME? And why a 100k for the GAIN, instead of the 50K of the original?
« Last Edit: August 26, 2008, 03:33:45 AM by Renegadrian »
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #34 on: August 26, 2008, 06:45:26 AM »
Just comparing the BC547C with the BC548C on their datasheets, they appear to have the same gain, the 'B' version has too little gain though, and probably wouldn't be suitable. You should socket the transistors though, just in case they don't work for some reason.
Volume - I'm going to build mine with a trimpot or resistor voltage divider (to achieve unity between the bypassed and effected signals) instead of a Volume control - you don't usually see tremolos with volume controls. As to 'why Lin and not Log', I've built a lot of synth stuff, where Lin in used for signals and Log for control voltages. Different pot manufacturers label their pots differently too, an 0MEG Lin is 'A', an Alpha Lin is 'B' - very confusing.
Gain - having a 100K instead of a 50K allows more resistance between the cathode and ground, and therefore more clean headroom. Again, I'm building mine without a gain control, I'll use a 100K resistor instead - you don't ususally see tremolos with gain controls either. I will also be using 100K resistors for both the plate resistors, again aiming for a clean sound.
So mine will just have two pots - 'Speed' and 'Depth'.
I've also made a few improvements to the design - just tweaks here and there - and one of the resistor values I posted was wrong (doh! - the first 4K7 at the emitter of the second transistor should be 47K), so hold off from building it for a day or two, to give me time to update the schematic.
« Last Edit: August 26, 2008, 07:37:04 AM by frequencycentral »
Renegadrian
thx
« Reply #35 on: August 26, 2008, 08:18:03 AM »
Well, I usually use sockets, so no problems...I'll try those BC548C
You wrote that with the depth pot at zero you have a standard valvy, right?
So I want to build it with all the pots then...
I'd have a standard valvy and a tremolo at the twist of that pot?
The way you'd do it it would use valvy part just to clean boost the sound...
Wait for the updates then!!! Thx for your useful explaination!!!  :icon_wink:
« Last Edit: August 26, 2008, 08:21:48 AM by Renegadrian »
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #36 on: August 26, 2008, 11:04:22 AM »
Here's the latest update, it's the version I'll be building. It's the 6111 submini version with no gain control and no volume control. I'm building mine as a tremolo only - no boost/overdrive - just unity gain between the bypassed and effected signals. Tremolos don't usually have gain/volume controls.
The tweaks are circled in red. (though somehow it seems to have changed to purple in Photobucket)
A. I've changed the gain pot for a 100K resistor - for hardwired clean headroom.
B. I've changed the 100K plate resistor for a 220K - to achieve unity gain between the bypassed and effected signals.
C. I've added a 1N4148 to negate a bit of LFO bleed I found.
D. This was 4K7 on the original schematic. It was a mistake! Oops! It should be 47K.
I'm still having problems adding a rate LED - it flashes nicely but it causes audible ticking - I've tried a few solutions (including Jack Orman ones) with no luck. I guess a rate LED isn't essential - but I won't let it beat me - so I will post the solution when I find it.
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #37 on: August 26, 2008, 01:29:15 PM »
..........and here, finally, is the way to add the LFO rate LED without causing any popping.
Renegadrian
« Reply #38 on: August 26, 2008, 02:05:17 PM »
so it should be that way? What is that 100k res at the base? Also, will this circuit work as a stand-alone (without the tube part) or it needs something to boost the sound???
  • Poster2
  • Total likes: 113
    • frequencycentral
« Reply #39 on: August 26, 2008, 02:20:56 PM »
Sorry - I don't understand the question.............???
EDIT: Aah - got it! No way Adriano - that arrangement would tick like a Swiss cuckoo clock at midnight! The LED circuit uses an EXTRA transistor. Like this:
« Last Edit: August 26, 2008, 02:33:59 PM by frequencycentral »
