My point was not that the 2nd example is the ONLY way to make a filter.
BUT that's what you said, friend... I was only reacting to that statement.
In order have a filter of any kind, you have to create some sort of voltage divider. Like this:
I don't think anyone is saying that R1/C1 make a filter on their own. HOWEVER! could it be that R1/C1 have an effect on the R1/R2/C1 filter, and that effect is INDEPENDENT of R2? Possibly? Would you sleep at night? I know I would! LETS LEARN!
Here's some data, I finally figured out how to get 5Spice to work.
Low Pass, R=1k, C=.22uF, like our Mid-Happy Friend the Tube Screamer. The cursor is centered about -3dB roll-off.
Here's a simulation of Projectile's expertly drawn low-pass/hi-shelf filter (foreshadowing?), using the values, R2=1k, C1 = .22uF and R1 = 220. It seems to level off at the value of 3.2kHz, as calculated by R1 and C1. Note: My definition of R2/R1 is reversed, and I forgot to center the cursor on -3dB.
Putting them together, again, cursor is arbitrary, and my schematic definition of R2/R1 is reversed.
note: i've used R2=1 ohm as zero, in order to general two plots together. There's no difference in the plots between r2=1 ohm and no resistor within this range.
As you can see, the addition of R1 after C levels off the filter, creating a "shelf" in the frequency response. The overall roll-off of the filter changes slightly, but not enough to warrant shouting BLASPHEMY at those who would explain this using 720Hz and 3.2kHz as "special" frequencies to talk about, more on that in a bit.
Oh, and just for gits and shiggles, here's what happens when we change the upper resistor. Two curves, R=1K and R=10K.
Note: Cursor is Arbitrary, and my schematic labeling of R1/R2 is reverse from the schematic at the top of the page.
The thing to note here is, the upper leg resistance changes the roll-off frequency, but the point at which things flatten out remains the same, (set by R=220). To me this says they are independent enough that we can talk about the 220/.22uF on its own. To clarify, in my professional DIY opinion (joke), it is not incorrect to talk about the 220/.22uF RC constant separately from the 1k/.22uF as they are more or less independent in this configuration. HIGH FIVE!
Next I intend to simulate how this affects a feedback loop in a gain stage, as well as the complete clip stage and tone stage of the TS, but tonight I've got to study for an Electricity and Magnetism Mid-Term!
Oh, and I'll probably start my own thread, or even post on my website.
Cheers.
If anyone is interested in 5Spice, it seems a bit easier to use than LTSpice, at least for first time users, I can provide some links. And its FREE. I can also point to a tutorial, with example for simulations. It's from the class I teach, associated with my research advisor so i'd rather not post publicly but I will respond to any PM's with the information.
