like life, it is a balance of forward momentum, doing what is needed at the moment to keep it moving, not getting bogged down in overly anal organization.
i know where almost everything is, and almost everything i need is within fast reach ( vertical emphasis, fluid tool/ material placement, willingness to mod everything in sight to accomplish tight workspace)
i like to stand while i work.
i like equiv 1000 watts of light shining on the work area ( approx 20% incandesc, 70% curlycue lightbulbs, 10% flouresc)
the middle 'stand' is the stage. a fluid area where different platforms get swapped in and out, but the key thing is that it gets the major work up at eye and hand level, up in the light.
the styrofoam tool storage 'stand' is glued quickly to a heavy piece of tile to keep it stationary. it is poked full of holes for the tools and new holes get poked or expanded all the time.
final note: the wire rack across the top contains not only wire, but my spool of solder so i never lose the solder. it is always hanging right where it can be grabbed quickly.
