New at runoffgroove.com: Tri-Vibe
Started by B Tremblay, December 24, 2009, 07:26:22 AM
Andre
Quote from: El Heisenberg on January 03, 2010, 05:30:54 AM
looks spectacular
Quote from: B Tremblay on January 03, 2010, 07:49:53 AM
Very nice work!  Thanks for sharing it!
Thanks, and thank you and Sebastian for this great circuit.
Quote from: flo on January 03, 2010, 07:56:09 AM
Looks great!
Did you use a printed transparent sheet on the enclosure?
Andre, do you take orders for a PCB?  ;D
Thanks.
I use sticky transparent photopaper with 3 layers of clearcoat.
And yes I do take orders for a PCB.
Quote from: Ben N on January 03, 2010, 08:14:20 AM
Very Fenderish esthetic--Leo would be proud.
In fact I was looking for the original Univibe font and found out it was exactly the same font Fender uses.
It's called "Brushed Script".
Quote from: Fuzz Aldryn on January 03, 2010, 08:32:09 AM
Hey Andre,
having trouble here with your posted layout. The signal passes the circuit unmodulated though checking the voltage tells me that the lfo is clearly working. I have to double check my build and your layout w :(
Regards
Helge
That's a pity.
I can measure some voltages for you if you want.
Fuzz Aldryn
Hi Andre,
would be very kind of you if you could do that. New day, fresh eyes, must be possible to get it to work.:)
Regards
Helge
flo
@André: Can you perhaps put your graphics design online? It looks great and I'd like to use it in mine if you don't mind. Thanks!
Fuzz Aldryn
Hi André,
I measured my voltages I got on the ICs. Maybe someone else would like to look over it.:)
Here's the link:    http://forum.musikding.de/cpg/displayimage.php?pos=-2235
Thanks in advance!
Cheers
Helge
B Tremblay
Quote from: Fuzz Aldryn on January 03, 2010, 12:29:45 PM
Hi André,
Thanks in advance!
Cheers
Helge
At first glance, pin 6 of the LM13700 has the voltage you'd want at pin 11 and vice versa.
B Tremblay
runoffgroove.com
Fuzz Aldryn
Wooops, thanks! I just mixed up left and right while writing it down.
Andre
Your voltages are pretty much the same as the mine.
The voltage on both pins 1 and 16 of the LM13700 should also vary a little.
I measure about 1.24. ~ 1.37V
Could you please check that?
Btw. Is there any clean signal when the switch is in the center position?
B Tremblay
B Tremblay
runoffgroove.com
stm
Quote from: Andre on January 03, 2010, 05:25:38 AM
Check out my finished Tri-Vibe:
Not too happy about the hole for the LED, but for the rest I like it a lot.
Really nice.  I like the B&W theme a lot.  May I suggest using a white LED?
Andre
Quote from: stm on January 03, 2010, 02:59:53 PM
That's a good suggestion, and if I put it in a cheap black LED holder, I can cover the rough edges of the hole at the same time.
Fuzz Aldryn
Quote from: Andre on January 03, 2010, 01:48:10 PM
Hi André,
yes to both. Still couldn't figure out the mistake.
Regards
Helge
Fuzz Aldryn
Hi to everybody envolved here,
shame on me! It was a bad speed pot!!! Damn it! I'm sorry to taken your time for such a stupid easy fix.:(
Regards
Helge
Andre
Quote from: Fuzz Aldryn on January 04, 2010, 06:42:48 AM
Regards
Helge
No problem.
I'm glad it's OK now.
Do you like it?
Fuzz Aldryn
yeah, I like it. It seems to close a gap I always had as I'm using a cheap Biyang MXR Phase 100 clone which is perfect for slow and deep phaser settings (have a listen to some of the Fu Manchu tracks) but sounds a bit crappy at high speed settings. The Phase 90 clone I have does that fast settings better but tends to distort with my pickups which always bothered me pretty much. The Tri Vibe fits perfectly into this fast speed gap. Cool!
Thank you and the guys of ROG - another fine piece of art (I have a ROG Thor on me pedalboard which will never leave me -tried so many ODs but nothing comes close to it thogh if have to say the MI Audio Crunch Box comes close to it but is even better as used as a boost for it.)
Regards
Helge
Very nice
Expect a vero layout shortly :)
svstee
B Tremblay
B Tremblay
runoffgroove.com
Stompin Tom
Ben N
Very nice. A bit daunting for perf, but very nice just the same. I've no doubt Rick Holt will do it. :)
danielzink
Quote from: Ben N on January 05, 2010, 04:26:56 PM
That perf could quite easily be converted to PCB..... ;D
Dan
