Fuzz Face tone control. Nobody thought of this?
Started by Morocotopo, April 24, 2010, 11:09:32 AM
Morocotopo
Hi gang. I´ve been struggling with the Fuzz Face, eventually I tried the Fuzzcentral Axis Face, a silicon, negative ground variation. Works rather well, but I never liked the Face´s high end, too fizzy. That schem uses a 0,033 uF cap across the original 330R (1K2 in this schem) to tame high end. But still too fizzy. When going to sleep, a lightbulb went off, and I came up with this tone control (before this I tried LP filters at the output, but they didn´t satisfy me):
Works quite well, tames the high end, gives, at least to me, much more versatility to this classic schem.
Now, I can´t believe I´m smart enough to be the first one to do this... anyone ever tried this idea? I, at least, never saw it anywhere...
Also, anyone sees any disadvantage to this mod? I mean, it works, but I don´t know if it causes any sort of trouble, I´m just a hack with a breadboard!
Morocotopo
Joe Hart
It should be fine because the net result is still the circuit seeing a cap of some value. Neat!!
-Joe Hart
Chugs
Weirdly enough, I thought of the same idea the other day after adding an input blend to a fuzz circuit. Great minds think alike!  ;D I haven't tried yet though. How much tonal variation does the blend give?
Morocotopo
Nice schems Gus, I haven´t seen your work before. Would you care to explain the function of the 100 Ohm resistor in the emitter of Q1? I´ve never seen that before. Don´t be mad, sharing is like that...  ;D
Chugs, it has a nice range of high end taming. At one extreme it´s the usual mosquito cloud, at the other it gets quite creamy.
Morocotopo
John Lyons
Ariel
That is the first time I've seen that configuration used in that place of the FF.
I've used a cap across the collector resistor and even the input and output blend
caps but I had not thought of the cap across the collector as a blendable cap.
Nice one!
Basic Audio Pedals
www.basicaudio.net/
joegagan
nice thinking.
interesting how beautiful solutions and ideas come to us when we are half asleep, waking up, dreaming.
Morocotopo
Yep Joe, half asleep is good.
;D
Not ALL the time, mind you. But, maybe that´s the key to Keith Richard´s success?
:icon_mrgreen: :icon_mrgreen:
Morocotopo
Quackzed
yeah , that looks like a keeper. but i'm not sure how much more abuse my fuzz can take  :icon_mrgreen: one more mod.
Paul Marossy
Quote from: joegagan on April 24, 2010, 01:46:40 PM
That's happened to me many times. But it's not always DIY related stuff.
Clever idea for the tone control.  :icon_cool:
brett
Hi
the variable roll-off is a super cool idea.
my 2c worth on the 10k/100ohm method...
The small emitter resistor (e.g. 100 ohm) seems to be a good idea, and means that you could use a garden-variety Si transistor as Q1 instead of a Ge without getting massive gain.  But consider what this does to the biasing, input resistance and tone.  If, for the purposes of comparing bias, we imagine an NPN, negative ground fuzzface, the base of Q1 is at 0.3 V (because it is one p-n junction above ground).  Si fuzzfaces have the base at 0.7 V.  Therefore, a Ge fuzzface has a lot less headroom and there is more clipping and the clipping is more asymmetrical than for an Si transistor with a similar hFE (e.g. a 2N2369A).  Also, the input resistance is low (proportional to the hFE and about 15k-20kohms), giving creamy tone and significant sag and bloom.
Now, add an emitter resistor.  The bias rises by the Ie x Re (about 0.05 V in the case or 10k/100ohms) and the asymmetry in the clipping falls a bit.  The input resistance is close to the hFE x the Re (typically 40k).  This means there's a lot less sag and bloom (hardly any compared with a low hFE transistor).  These may be reasons why Ge appeals to so many people, even though their availability and quality are low and the price and nuisance value is high.
cheers
Brett Robinson
mac
Bien pensado Ariel!
You gave me another idea I'll try tomorrow: I'm going to replace the 330R with a 500R or 1k pot, wiper -> cap -> Vcc.
mac
Morocotopo
Gracias Marcelo! Muy de vez en cuando la neurona se activa...
:icon_mrgreen:
You mean, R and cap in series? What would that do? Hmmm.
Morocotopo
WGTP
#13
Seems like someone did the variable cap deal with the big electrolytic on the Fuzz control some time back...   May have been Joe.  The input cap also.
Seems to be enough places on the FF to add 1st order low pass filters that they end up cascaded for 2nd 12db/oct or 3rd 18db/oct order roll off.  :icon_cool:
Stomping Out Sparks & Flames
mac
QuoteYou mean, R and cap in series? What would that do? Hmmm
No, the cap is in parallel with part of the pot. I tried it today and it works fine.
          500R linear
vcc ------//////----------//////------Q2 collector
             |              8k2
            === 47nf
vcc ---------
mac
Morocotopo
#15
Oh, ok. Functionally it´s the same as my mod? Or different? how does it sound?
I´ll see if I can make some sound clips of mine.
EDIT: Ok, some quick, out of tune, semi awful sound clips. One straigt into the computer via mixer:
http://www.zshare.net/audio/75460839a2acfda4/
Fuzz Face tone test no amp sim.mp3 - 2.56MB
First with tone 100%, then half, then 0%. Some guitar vol control fiddling. P 90´s mid position.
Same through a software amp sim, clean amp setting:
http://www.zshare.net/audio/75460927958e8946/
Fuzz Face tone test w amp sim.mp3 - 2.56MB
Morocotopo
Electron Tornado
Yep, I'm diggin' it. Sounds nice.   :icon_smile:
Going to have to try it.
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
mac
It works different because when cap is on the vcc side it does not cut highs.
mac
Morocotopo
So it goes from "not cutting highs at all" to a variable amount of cut? Is that right? In essence, a tone control with more range?
Morocotopo
mac
QuoteSo it goes from "not cutting highs at all" to a variable amount of cut? Is that right? In essence, a tone control with more range?
Yeap. I used a 47nf but can be increased to 100nf to cut even more highs.
Here is the schem (have you ever tried to draw schems using Paint?  :P)
mac
