simple 2 knob hi gain distortion..collaboration?
Started by deadastronaut, August 13, 2010, 04:41:57 PM
nice one keeb!......now lets play the bastard... :icon_twisted: :icon_twisted: :icon_twisted:
rob.
arma61
hi, this is my version of the B...d  (ExpessPCB and ExpressSCH for those who want to "play" with it)
(it's related to page2 schem)
    .SCH file
    .PCB file
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
mhartington
Tone stacks?
great sounding pedal but im looking for suggestions in tone stacks. Maybe a three band Marshall tone stack or something similar. Any suggestions out there?
caspercody
WGTP
#185
Sort of late, but have you seen these?   Check out the Rambler, Smokey Amp and Stupidty Box.  Great site.
http://web.archive.org/web/20050119104631/www.geocities.com/tpe123/folkurban/fuzz/snippets.html
Has anyone tried the JRC version?  Tim seems to think that is the way to go.  Radio Shack used to have them.  :icon_cool:
Stomping Out Sparks & Flames
Quote from: Scruffie on September 15, 2010, 02:29:48 PM
Quote from: caspercody on September 15, 2010, 02:29:10 PM
Baxandall tonestack.
Seconded.
good to see more dudes onboard with this..
@ scruffie . would the baxandall tonestack give a good classic scoop to it!..? ???
Scruffie
#187
Quote from: deadastronaut on September 16, 2010, 07:19:42 AM
Seconded.
Yes and the nice thing is, with the right values you can have it give you a scoop at some settings but with both knobs at say 8/9 o'clock, flat mids... I might have the values for such a tone-stack, i'll have a look, or you can play about in Duncans yourself.
Quote from: Scruffie on September 16, 2010, 07:24:33 AM
Seconded.
sounds cool....can you post it up here..so we can all play about with it..cheers man. rob. :icon_cool:
edit: just had a look around...baxandall..bass and treble only? no mid?.. ???
@ armando...
so you went with the 'dreadnought ' then...less offensive eh?...ha ha..cool. :icon_mrgreen:
Scruffie
Quote from: deadastronaut on September 16, 2010, 07:28:38 AM
Seconded.
Yeah that's what a Baxandall is, the two have an effect on the mids though depending on setting and unlike the Big Muff Tone control don't suffer the annoying See-Saw Effect of Treble means no Bass and Bass means no Treble. It's nice because it's simple and has a good amount of control for 2 knobs, if you wanted you could add in a switch to scoop or flatten the mids too.
got ya!...there is no 'baxandall' in the tsc though!...or am i missing something?.
would be nice to actually hear the baxandall on it, if anyone does it!...
i have a small breadboard with a bass/mid/treb tonestack on it for such experimental purposes...i'll mess around and see what happens.
NB: the initial idea was to have a 'simple' distortion without the trimmings of a tonestack, just to get the distortion 'right' first....
but now that is done it would be nice to have more control i agree...'the super b''''''d..(dreadnought).ha ha... :icon_mrgreen:
i'm guessing the output 1M on the distortion would have to be removed though, to lift the tonestack...otherwise output would be to quiet yes?... ???
Scruffie
#192
Quote from: deadastronaut on September 16, 2010, 08:36:13 AM
It's labelled 'James'.
Quote from: Scruffie on September 16, 2010, 08:37:24 AM
It's labelled 'James',
got ya!.. :icon_redface: :icon_redface: :icon_redface:
arma61
....if all we are looking is " that kind of sound with that mid scoop and that quantity of treble and bass" it shouldn't be hard to have a "fix" tonestack, I mean ( and here you live-player can correct me) you are not going to change tone setting every song or two on stage, isn't it ?
....so once you've got on a breadbord the tone you like (combined with your axe and your amp)  just stick the right value of res and caps and you'll have your 2 knobs distortion with the tone "you were looking for", though I don't know (yet!) how to build a tonestack with fixed component, but that should not be that hard.... ok if it's build for friend/selling that's another story....
Dreadnought...... yeah I like the "name" and I like also how it sound when pronounced by you English native speaker!  :D
hi armando.
yeah the distortion sounds great on the amp anyway..using the amps eq..i agree!.
nice to have a little control at your feet too..when i was messing with it originally i messed with changing caps to best suit my
axe and amp...other setups may need a bit of eq tweaking...according to their axe/amp though!.
'dreadnought' the battleship. pronounced in english...dered -nawt... :icon_mrgreen:
other useful english phrases.:as pronounced:
cuppa tee= cup of tea
bluddy el=bloody hell
get ahht the fahhhkin moata= could you please exit the vehicle :icon_mrgreen:
heres the built vero..tiny eh!.. (my cat decided to tap it onto the floor after i sprayed it.
thats why its a rough finish.... :icon_rolleyes:
WGTP
Are you going to put the tonestack at the end, or between the Jfets and 386?   :icon_twisted:
IIRC someone rescaled a tonestack to work at the end of the 386 because of it's low output impedance maybe.   :icon_cool:
Quote from: WGTP on September 16, 2010, 03:05:26 PM
hi. at the end of the circuit!....on this vero...
do you mean this?
http://www.diystompboxes.com/smfforum/index.php?topic=83372.0
WGTP
#198
Looks like you have already done a vero for one.  For simplicity, I'd recomment the BMP stack.   :icon_cool:
http://www.diystompboxes.com/smfforum/index.php?topic=65308.0
http://www.diystompboxes.com/smfforum/index.php?topic=71680.0
That one looks scaled by a factor of 10.  The other one uses a factor of 15 IIRC.
cheers wgtp.
yep i also built the bi muff tones stack...didnt really get on with that.cheers though man.
some guys suggested the baxandall..havent tried it yet..
im after a good mid scooped control, and not to trebly...been looking at the tsc , i also noticed daniel schwartz said
what he sees on the screen with the tsc doesnt sound like it in reality...so i think its going to be a bit of trial and error on various
types of stack, with modifications to suit my ears...any other suggestions welcome though!.. :icon_mrgreen:
cheers rob.
