Tube Screamer need debugging help!
Started by 0ron124, December 29, 2010, 01:10:50 PM
0ron124
Hi all,
So here's the low down. I followed this post for the information http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
I believe it is a problem with the ground circuit somewhere.
1. When the curcuit is bypassed there is a clean sound. When you turn the effect on you just get dead silence however the power LED is on.
2. Effect: Tube Screamer w/ Expensive Boutique Mod by General Guitar Gadgets
3. http://www.generalguitargadgets.com/projects/17-distortion/82-its8-tube-screamer-808-replica-project
4. No
5. None
6. Ummm not sure
7. 9.05v
Voltage at the circuit board end of the red battery lead = 9.05v
Voltage at the circuit board end of the black battery lead =  9.05v
IC
1 = 8.5v
2 = 8.5v
3 = 8.5v
4 = 0v
5 = 8.5v
6 = 8.5v
7 = 8.5v
8 = 9.05v
Q1
C = 4.9v
B = 5.2v
E = 9.05v
Q2
C = 5.2v
B = 5.6v
E = 9.05v
D1
A = 8.4v
K = 8.2v
D2
A = 8.2v
K = 7.9v
D3 – Red LED
M (-) = 0v
P (+) = 8.5v
D4 – Red LED
M (-) = 8.5v
P (+) = 8.5v
D5
A =  0v
K = 9.05v
ayayay!
Go back and check your voltage divider:  R9 & R10.  Between those two resistors you should be getting approx 4.5v (that's the Vr in red on the schematic.)  Everything everywhere in your debug list points to full voltage where it shouldn't be...   ;)
And it appears Q1 & Q2 are reversed.
The people who work for a living are now outnumbered by those who vote for a living.
0ron124
Thanks for the speedy reply.
I checked the voltages between R9 and R10 I get 6.8v on both. As for the transistors I labled them backwards my bad...
Johan
do you have a cable plugged into the input. the black cable from the input jack to the circuit board should read 0volt, not 9volts,suggesting there is no monoplug plugged in or the jack is misswired.
J
DON'T PANIC
ayayay!
Quote from: Johan on December 29, 2010, 01:51:42 PM
J
Ahh, I was wondering how he was getting that.  That's a possibility, a TRS cable...
Quote from: 0ron124 on December 29, 2010, 01:39:41 PM
Something's not quite right there.  Either you're using a 12v supply, or you've got a resistor that's maybe 1k and one that's 10k, something like that.  Or the ass end of R10 isn't connecting to ground.  Something funky is up there that I'm not getting...  It doesn't explain why you'd have MORE voltage than that down the line...
Good to know the trannies are in right now.  Have you remeasured them since?
0ron124
J
Yes I do have a cable plugged into the input jack. I also am getting 0 volts on the black wire into the board. So does that mean something is up with my cable?
I'm using a boss PSU 9v adapter. If I remember correctly there was something funky going on with my ground. I'll check it out and post back.
I'll also remeasure them while I'm at it.
0ron124
Ok so I just checked the voltages for the IC and the Trannies their the same as before. I also checked to be sure and both R9 and R10 are 10k resistors.
While I was at it I resoldered R9 and R10 just to make sure everything was good and rechecked the voltages. I have 5.6v on both of them and 9.05v before them.
  Check first that +/- are Not Connected.
  Measure PS before, then after connecting it.
  Because you are registering voltage at the opamp, I suspect this is a typo, both battery leads measuring the same voltage is either a miscommunication or sounds wrong, maybe I'm misreading it somehow.
  It looks like the voltage divider isn't biasing the opamp Inputs and outputs.
  What voltage do you measure where the two equal value divider resistors meet ?
twabelljr
#8
Quote. I have 5.6v on both of them and 9.05v before them.
R9 sould have your source of 9.05V on one side and approx. 4.5V on the other side. R10 should have approx. 4.5V on one side and 0V on the other. Without R10 grounded on one end there is no voltage divider to provide your bias voltage.
Your voltage measurements at the IC show only a 0.55V drop.
Shine On !!!
> 1 = 8.5v
> 2 = 8.5v
> 3 = 8.5v
> 4 = 0v
> 5 = 8.5v
> 6 = 8.5v
> 7 = 8.5v
> 8 = 9.05v
> Q1
> C = 4.9v
> B = 5.2v
> E = 9.05v
> Q2
> C = 5.2v
> B = 5.6v
> E = 9.05v
You got plausable (a bit high) voltages at Q1 Q2 Bases.
Ah, There is a short between the _IC_ ends of R5 R16 and VR. (Figure R9 as really R9||R5||R16: 6.8V.)
Is your IC in right-way-round?
0ron124
Ok so I got it working! Thank you all for your help. I turns out R10 was registering at 5k ohms instead of 10k which it is marked at as well as a bad IC. I just swapped the IC with a spare I had and it was good to go. Thanks again everyone sounds awesome!
ayayay!
Bingo!  Awesome man, congrats!  Nice work on debug posting too.   ;)
0ron124
Ok well apparently I spoke too soon. I should have tested the tube screamer more throughly. I discovered it wasn't working again after I decided to put it in it's enclosure. Anyways, the new problem is when the effect is engaged there is very little distortion and with the gain knob at full bast. Here's the new voltages.
IC
1 = 4.5v
2 = 4.5v
3 = 4.5v
4 = 0v
5 = 9.05v
6 = 4.5v
7 = 4.5v
8 = 4.5v
Q1
C = 9.05v
B = 3.76v
E = 3.31v
Q2
C = 9.05v
B = 3.98v
E = 3.63v
D1
A = 4.07v
K = 4.5v
D2
A = 4.5v
K = 4.3v
D2b (in series with D2)
A = 4.3v
K = 4.14v
D3 (Red LED)
P (+) = 4.5v
N (-) = 3.3v
D4 (Red LED)
P (+) = 3.3v
N (-) = 4.5v
D5
A = 0v
K = 9.05v
twabelljr
Did you mix up IC voltages 5 and 8? they seem backwards. Typo maybe??
Shine On !!!
0ron124
Oops...yeah that was a typo on my part. Thanks for catching it. Anyone have an idea of what's wrong?
So what changes when you put it back in? Usually busted or loose wires. Sometimes unecpected grounding.
Stuff like that, you have to find by inspection.
ayayay!
Seems to me you've done some good t-shooting to this point, but it's time you build a probe and trace this thing audibly.   :)
http://www.diystompboxes.com/pedals/debug.html
