Hey guys,
I have a problem I am struggling to find a way to solve, I was hoping you guys could help me out.
I'm in the process of planning my new pedalboard. I have a Whammy IV which I will be controlling with a Molten Midi 2. The MM2 can be programmed via it's MIDI port.
I plan on having a MIDI In jack mounted on my board near all the 1/4" inputs and outputs for the guitar signal which I will plug my MIDI interface into so I can reprogram the MM2 without taking it off the board or dicking around with it.
What I need to be able to do, is to be able to swap the Whammy out in place of the board MIDI connector. Essentially an AB box.
So it should switch from:
Whammy IV (A) -> MM2
to
Board MIDI Connector (B) -> MM2
Can anyone suggest a solution for this?
