I want to be able to program SMT microcontrollers after they are mounted.
I have a 14 pin narrow clip, but if you want a really compact design, that won't work.
I could obviously put a 5 pin header on the board, but I want to avoid that because I don't want anything extra sticking up and it would really only be fore a single use therefore a waste of parts.
I am imagining 5 pads on the board and some some sort of spring loaded 5 pin probe-type device. So you would press down the probe and connect to all 5 pads (or vias) and program the uC in circuit.
Is there anything remotely like this, or is a pin header the only answer?
