RG Posted a detailed explanation' of FF activities at GEO, it is the most concise and complete one I've seen, as concise as it is, it is long and critical parts of understanding electronics then FF are dense also. I found it useful to gather plenty of reading material to help assist in trying to comprehend it...there's more at GEO, etc.
You will probably have wished to have a working FF [if you're like me] before you gain mastery over electronics or even the two transistor feedback loop amplifier [FF].
So...in the meantime, FF debugging tends to help develop 'chops'.
The voltage measurements are critical to the math of finding the numbers that will tell you 'bigger or smaller' for Q2 collector resistor.
IF the rest of the circuit is 'good', a variable resistance for Q2 collector resistor can bias all usable transistors:
Starting with the 'base' resistance [stop resistor] of say 6k8 and adding 0.0k - 10k [a 10k pot does vary R from 0.0k - 10k].
This gives 6k8 resistance with the pot turned to 0.0k, and 16k8 resistance with the pot all the way 'up' [6k8 + 0.0k = 6k8 // 6k8 + 10k = 16k8]
With this collector resistor set up, dialing in anything between 6k8 and 16k8 is quick and easy, and allows biasing of most usable Q's for FF's.
Q2 collector should sit at or around 1/2v of the power supply [that'd be 4.5v if using a 9v battery] allowing room for it to swing + and - from the bias point without 'hitting' the extremes of the PS: Ground and 9v...biased right in the middle works, adjust to taste from there.
Because the diode in the transistors causes a diode drop and for other reasons, many like their FF's biased at 5v or 6v, also for assymetrical clipping [hits one of the power rails sooner/harder than the other]
By posting the voltage or using the variable Q2cR depicted above, feedback about the transistor pin voltages will tell whether there's a problem, maybe even where there is a problem if there is one.
Smaller resistances between Q2C and 9v 'pull the voltage up' toward 9v supply, larger resistances make Q2C voltage drop, adjusting the pot [trimpot or offboard] + 6k8 to some resistance which brings Q2C voltage near the middle of the supply voltage is what we're looking for. It'll do that if everything else is right.
