Author Topic: X FUZZ  (Read 159690 times)
Re: X FUZZ
« Reply #400 on: August 22, 2020, 01:30:49 PM »
Domin
Re: X FUZZ
« Reply #401 on: August 22, 2020, 02:25:29 PM »
I put that pcb in breadboard, input of PCB i connected to one jack, output to 500k pot and output of pot to anothe jack and firstly I had clean signal, I measured collector voltage and it was above 9V and then I unplugged in and out, measured voltage and it was around 3V so I change resistor in second transistor from 10K to 5,1K and it went to around 6V, then I plugged in and out and it was back above 9V...
Re: X FUZZ
« Reply #402 on: August 22, 2020, 02:40:49 PM »
have you got any stripboard?
if so, here is my original layout.
https://www.dropbox.com/s/oe7d6misxqa7qxt/xfuzz%20vero.jpg?dl=0
Domin
Re: X FUZZ
« Reply #403 on: August 22, 2020, 02:57:47 PM »
I dont have stripboard, just protoboard but I made layout by your schematic, maybe this will work better than layout before...
Re: X FUZZ
« Reply #404 on: August 22, 2020, 03:00:07 PM »
cool...... 8) 8) 8)
let us know how you get on...
Domin
Re: X FUZZ
« Reply #405 on: August 22, 2020, 03:10:37 PM »
Does it look ok? Ok, maybe tommorov I,ll try it, I hope :/ But thanks a lot :)
Re: X FUZZ
« Reply #406 on: August 22, 2020, 03:13:53 PM »
connect the other 10k to 9v.... and add a ground on the bottomn of the diode...
Domin
Re: X FUZZ
« Reply #407 on: August 22, 2020, 03:15:25 PM »
Ah sorry, I was moving with resistors so I forget to make line to second resistor...
« Last Edit: August 22, 2020, 03:19:05 PM by Domin »
Domin
Re: X FUZZ
« Reply #408 on: August 22, 2020, 03:25:54 PM »
And one more question, you said that 1uF cap should be nonpolaryzed, what will happen if I use electrolyt?
antonis
Re: X FUZZ
« Reply #409 on: August 22, 2020, 04:42:45 PM »
Great uncertainity concering its leggings.. :icon_wink:
P.S.
Electrolytic capacitors aren't necessarily polarized..
(at least, for a couple of μF values..)
« Last Edit: August 22, 2020, 04:52:44 PM by antonis »
Domin
Re: X FUZZ
« Reply #410 on: August 23, 2020, 03:04:32 AM »
Ok I made it and its just amplifying, I used blue LEDs instead of yellow
Domin
Re: X FUZZ
« Reply #411 on: August 23, 2020, 03:13:28 AM »
I put yellow ones and no change, when Im no playing I have only some hum in really low pitch
Re: X FUZZ
« Reply #412 on: August 23, 2020, 03:47:32 AM »
Show us a close up of your breaboard....
Domin
Re: X FUZZ
« Reply #413 on: August 23, 2020, 03:57:08 AM »
Sorry but I dissasembled it...but I checked it twice with my father and it was ok...I tried simple bass fuzz but it had same problem, just amplifying and not distorting...
« Last Edit: August 23, 2020, 04:01:23 AM by Domin »
Re: X FUZZ
« Reply #414 on: August 23, 2020, 04:15:22 AM »
Hmmmmm wierd that its happening with 2 different circuits....
If i get a mo i will draw up a breadboard with the xfuzz on ok.
And we will go from there.....we WILL get this bugger going ok.  ;)
Domin
Re: X FUZZ
« Reply #415 on: August 23, 2020, 04:20:35 AM »
Ok, thanks, but I dont understand it, I would understand if transistors were bad, but they are conductive from base to collector and from base to emitter and voltage is around 800mV, one side has more mV than other, but maybe only 20vM more, I tried 2N5088, BC549C, BC547C and same...Collector voltage is only 25mV lower when I put 100K resistor instead of 10K, something is making problems and I dont know what...
Re: X FUZZ
« Reply #416 on: August 23, 2020, 04:29:29 AM »
Indeed, very strange......
11-90-an
Re: X FUZZ
« Reply #417 on: August 23, 2020, 04:37:29 AM »
if that bazz fuzz failed....
can we have pictures of your in/out jacks that you connect to your breadboard?
flip flop flip flop flip
Domin
Re: X FUZZ
« Reply #418 on: August 23, 2020, 05:24:24 AM »
Bazz Fuzz I once made with 2N5088 on breadboard and it was working, so I made it on PCB and its great, then I started to have problems with effects...
Probably i found what was making problems
Edit: I used 100nF cap in clipping section but its working!!! Noe i need to find why my pcb isnt...
« Last Edit: August 23, 2020, 05:53:00 AM by Domin »
Re: X FUZZ
« Reply #419 on: August 23, 2020, 06:01:26 AM »
well at least you have something working yay........ 8) 8) 8)
