Did you figure which hole from the 2.7k goes to ground? That one. It's ground. The pot pin 1 goes to ground. There.
If you want to put a 1k between there and the pot, do it. Better to first put the wire in, confirm it works....,
....then cut the wire and splice in a 1k (or other small value.) Having the R soldered in at one end and free to wiggle is bad housekeeping. Having the R soldered at Bothe ends to the wire and somehow shrink tubed or looped around to strain relief is smarter.
