EHX Small Clone mods?
Started by zachlovescoffee, October 09, 2021, 11:31:24 AM
idy
First you try (test) with one CLR. You may find that only one LED lights (lower forward voltage, red). Then you will need seperate CLR. Adjust for same brightness. No one can tell you what values, you have to try your LEDs and adjust.
Why is it impossible to mount a bi color but easy to mount two seperate LEDs? Can't visualize this. If its a different size and you want to use a bezel there are other sizes of bezel....
idy
To be clear: If you use the CLR for the common anode (both anodes twisted together) you don't need two resistors. Only one LED at a time is powered up. You only need two if you are tweaking on brightness differences.
zachlovescoffee
Got it! One CLR off the main power. Split to each anode. Works like a charm.
