Author Topic: Pictures!  (Read 12305261 times)
Re: Pictures!
« Reply #25480 on: April 19, 2015, 06:54:11 AM »
the difference between clear plastic and aluminum?
Could be "transparent aluminum", of course...   ;)
Re: Pictures!
« Reply #25481 on: April 19, 2015, 07:37:50 AM »
This could go in the silly pedals thread but I think he looks too serious for that.  ;) My Mini-Me Chorus with board from GuitarPCB.com. Yeah, it's a Small Clone. I had to read the build document and think longer than I would like to admit to get it. lol.
[I'm still playing the botophucket.com roulette, so if this image is the one I think ....] why do I find this pedal visually disturbing? good looking, but still disturbing (unless it's the gut shot), and I had to reduce it a little.
[edit :] spellink
« Last Edit: April 19, 2015, 07:49:47 AM by duck_arse »
bloxstompboxes
Re: Pictures!
« Reply #25482 on: April 19, 2015, 09:57:57 AM »
Could it be the placement of the switch relative to his crotch/ It's a little off though.
rocket8810
Re: Pictures!
« Reply #25483 on: April 20, 2015, 12:15:49 AM »
I usually don't post pictures of my builds, but figured i would post my last two. These are the first etched enclosures I've ever done and I'm pretty happy with the results.
This is a modified blacksheep, which is just a slightly modified roland beebaa
and the gut
This is the last one I build. I finally had time this weekend to finish this since I etched the enclosure last week. It's a modified Ezekiel 25:17.
and the gut shot.
~arph
Re: Pictures!
« Reply #25484 on: April 20, 2015, 03:40:16 PM »
Nice builds!
it's vengeance btw.
storyboardist
Re: Pictures!
« Reply #25485 on: April 22, 2015, 09:31:04 AM »
Finished up a couple things last week. First was this Rams Head BMP clone with a tone voicing switch. Allows you to have the stock scoop, flat, or boosted mids.
And I finished up this 2-in-1 box. Supro T16 emulator on the left, Heart Throb tremolo on the right.
Re: Pictures!
« Reply #25486 on: April 22, 2015, 09:42:15 AM »
nice rams head design...elegant. 8)
rocket8810
Re: Pictures!
« Reply #25487 on: April 22, 2015, 01:52:47 PM »
Man. Love those slanted cases and gorgeous simple design.
Re: Pictures!
« Reply #25488 on: April 23, 2015, 10:36:28 AM »
storyboardist - that is a nice looking wedgie. can you please tell me, which way is clockwise with those pots?
storyboardist
Re: Pictures!
« Reply #25489 on: April 23, 2015, 02:14:03 PM »
Thanks man. The knobs in the 2nd pic are set at "noon" so clockwise would be to the right as you'd look down at it if it were on your pedal board. Hope that makes sense.
trixdropd
Re: Pictures!
« Reply #25490 on: April 23, 2015, 02:37:40 PM »
1st pictures post!
Here's a MIDI controlled switcher for Blackstar amps with the DB-9 FS input
sajy_ho
Re: Pictures!
« Reply #25491 on: April 24, 2015, 09:01:02 AM »
Guys look here; something for laugh :icon_lol:
It's basically an Ibanez WH10, inside a broken sewing machine pedal. It was one of my first diy pedals, opened it last night and did Mark Hammer's "Range pot mod" and now it becomes my favorite ;D
The funniest part is the wah pot:
« Last Edit: April 24, 2015, 09:31:56 AM by sajy_ho »
Life is too short for being regretful about it.
Re: Pictures!
« Reply #25492 on: April 24, 2015, 10:34:06 AM »
I was looking in your bucket, thinking 'nice use of the pots ...', and then though 'how he wah-potting?'. I did larff when I saw the cam-actuator-thingy. your first, you say?
storyboardist - it goes make sense when explained and examined, yes. I am always interested in the thinkings applied to on-the-sides pots.
sajy_ho
Re: Pictures!
« Reply #25493 on: April 24, 2015, 11:50:53 AM »
Yeah man :icon_lol: It's kind of 'Wheel and axle' thing, with the pot acts as the axle. If I remember correct I used a 500k pot so a little turn will act like a 50k pot, all connected with a steel wire and a huge glue mess!
alanp
Re: Pictures!
« Reply #25494 on: April 24, 2015, 06:58:30 PM »
1st pictures post!
I like the header connection for the two green boards, might have to pinch that idea at some point :)
trixdropd
Re: Pictures!
« Reply #25495 on: April 24, 2015, 07:06:37 PM »
1st pictures post!
It works well. Thanks!
mth5044
Re: Pictures!
« Reply #25496 on: April 27, 2015, 04:52:23 PM »
Parallel Boost and Reverb. Boost is Tubescreamer with LED's and move volume on tap. Reverb is similar to 1776's new reverb using the Belton Brick 3. Tone, dwell and volume inside with Mix control outside. Used in parallel so that boosting only increases the dry signal and doesn't make the reverb louder. (I did eventually remember to put the IC's in.)
GEOFEX's 7 Band EQ made to run on +/-9V with each band being selectable via toggle. Remind me never to never again do a modular design to save money.
Madbeans' Aquaboy Deluxe with MN3005's. Had to do some cutting and shaving to get those jacks in.
All the writing is done with paint pens. I have terrible hand writing.
Luke51411
Re: Pictures!
« Reply #25497 on: April 27, 2015, 04:58:26 PM »
That modular design is slick! But yeah... lots of offboard wiring would be a PITA. It was done well though! cool builds all around!
Re: Pictures!
« Reply #25498 on: April 28, 2015, 12:02:43 PM »
love the eq Matt, my kind of pedal. bravo!
Re: Pictures!
« Reply #25499 on: April 28, 2015, 12:06:05 PM »
+1 mad build... 8)
