Author Topic: Pictures!  (Read 12309563 times)
LakeFX
Re: Pictures!
« Reply #25860 on: August 24, 2015, 06:34:18 PM »
Here's my most recent build. It a modified FDECK HPF preamp with input switcher and independent volume controls for doubling on bass. My wife did the artwork.
tasos
Re: Pictures!
« Reply #25861 on: August 27, 2015, 07:40:49 AM »
There you go!A feedback looper pedal.Super easy to build,this is actually a wiring project  ;D
Re: Pictures!
« Reply #25862 on: August 28, 2015, 02:27:01 AM »
Mac Walker
Re: Pictures!
« Reply #25863 on: August 29, 2015, 09:35:36 AM »
Did a run of new style wedge enclosures, here is a finish sample in gold and silver.
These are available in the registered, for sale section.
And a customer example:
Pettol
Re: Pictures!
« Reply #25864 on: August 29, 2015, 08:06:09 PM »
pickdropper
Re: Pictures!
« Reply #25865 on: August 30, 2015, 01:51:16 AM »
Re: Pictures!
« Reply #25866 on: August 30, 2015, 10:38:54 AM »
sheet! nice.
peterg
Re: Pictures!
« Reply #25867 on: August 30, 2015, 11:20:25 AM »
A Big Muff Pi:
« Last Edit: August 31, 2015, 07:50:15 AM by peterg »
Re: Pictures!
« Reply #25868 on: August 30, 2015, 11:50:47 AM »
Gorgeous inside and out Peter! No idea how you've done the top, an etch with multiple colours?
Clean, clean ,clean...
dave
KSG
Re: Pictures!
« Reply #25869 on: August 30, 2015, 02:52:37 PM »
Hello, guys!
Here is my Big Muff Civil War (mentioned earlier) with LIVE LED:
http://youtu.be/k2_sLVcHPz0
It's pity, but camera of mobile phone cannot reliably display the play of colors...  :(
(Guitar player is my friend).
Use it or lose it.
storyboardist
Re: Pictures!
« Reply #25870 on: September 01, 2015, 10:22:35 AM »
Here's my latest build. Super OCD – a souped up OCD designed by Fred Briggs.
It also has an internal charge pump so you can switch between 9 and 18 volts
Guts - layout can be found on my blog.
diydave
Re: Pictures!
« Reply #25871 on: September 02, 2015, 12:44:45 PM »
Summer is ending, so are these:
A Chorus
Which is just a rehousing because I didn't like my first attempt for it.
A Triband equalizer with added gain/drive knob
roseblood11
Re: Pictures!
« Reply #25872 on: September 02, 2015, 03:02:50 PM »
Nice one!
Does someone here know Fred Briggs personally? He didn't post for a couple of years now...
Luke51411
Re: Pictures!
« Reply #25873 on: September 02, 2015, 08:43:07 PM »
Dead astronaut spitfire metal n blues with an added clean blend for a bass player. This is a rehouse so the wiring isn't too pretty.
Re: Pictures!
« Reply #25874 on: September 03, 2015, 03:14:06 AM »
^^  Cool paint job.   :icon_cool:
KSG
Re: Pictures!
« Reply #25875 on: September 05, 2015, 12:04:50 AM »
Hello, guys!
Here is my FET X-amp overdrive. The main idea was borrowed from the amplifier Carvin: amplification, attenuation, then amplification and attenuation again several times for getting smooth and sweet overdrive. I used only 5 overdriving stages instead of 15 at original - I decided that it will be enough. I borrowed tonestack from BSIAB-II (with mids control knob), and also I added 3-position CUT toggle to eliminate harsh components of sound. FET-transistors are taken from broken condenser microphones: they are low noise and high gain and cost nothing.
guts:
Also here is internal switch FAT at the left corner of the PCB.
« Last Edit: September 05, 2015, 12:11:37 AM by KSG »
Use it or lose it.
Pojo
Re: Pictures!
« Reply #25876 on: September 05, 2015, 03:49:55 AM »
So here's a little project I've been messing around with for a while...like 8 or 9 months of constant tweaking. It's my own circuit but nothing terribly innovative. Just some common building blocks arranged in my own way and I've been really happy with the results. Here's a shot of my last 2 builds showing the guts and the completed top all at once. Basic idea is starting with a non inverting opamp stage with mosfet clippers wired up for ultra soft clipping in the feedback loop (credit to Mr Orman for this idea!). That gets cascaded into a pair of 2n5457 stages with careful attenuation and filtering between stages. The other half of the opamp wraps everything up with a run of the mill buffer for reliable interaction with whatever's downstream.
If you're curious what this all sounds like here are some clips demoing the mid gain tones here: https://soundcloud.com/pojofx/
Please excuse any weirdness in this post...I'm quite a few sheets to the wind on this fine early sat morning :)
« Last Edit: September 05, 2015, 03:55:18 AM by Pojo »
Luke51411
Re: Pictures!
« Reply #25877 on: September 05, 2015, 08:50:14 AM »
WSG: Wow! That is very cool. You salvaged smd components?
Pojo: great design!
KSG
Re: Pictures!
« Reply #25878 on: September 05, 2015, 09:58:31 AM »
 Luke51411: Yes, I often reuse SMD components from old cellular PCBs, I have a lot of them.
Use it or lose it.
Luke51411
Re: Pictures!
« Reply #25879 on: September 05, 2015, 10:39:59 AM »
That's pretty neat! How do you salvage them? You're not desoldering one at a time are you :icon_eek:
