Lots of folks playing around with multi-effect in one box.
So here's mine.
Last month I put five boosters temporaraly into one box
http://www3.telus.net/david65/pedal-pics/Superbooster-front.JPGFetzer, AMZ Mini-booster, Stratoblaster, Brian May Trebble boost and Range Master.
After playing around with those five I came up with two booster combination that made sence to me.
The first is a combo Mini-booster and Brian May Tebble booster. I like how these two sound inseries and individualy.
So I mounted them with a 3PDT footswitch and DPDT toggle.
This gets me...
With toggle up; the footswitch select between bypass or Mini-booster
With toggle down; the footswitch selects between bypass or Mini-booster in series with Treble booster.
This isn't what I was after but it's what I got.
The paint is kinda cool Krylon Mystic Prism. As close to a metal flake finish as you can get in a spray can.
It has irredecent glitter, but it dosn't show in the photo.
The second booster combo is the Fetzer Valve and Stratoblaster.
The Stratoblaster struck me more of a unity gain buffer than a boost. It sounds great with it's pot set at min.
So I mounted them both in one box with NO bypass. Footswitch selects between Fetzer (with knob) and Stratoblaster.
The Stratoblaster's pot is just crammed into the box but I'll get around to fixing that.
With my growing chain of true bypass DIY pedals I need a buffered booster at the top of the chain so I can kill the boost without going into capacitance tone suck mode. Pic is not much but the you all should get a laugh at the cram job. I didn't even trim the power leads in case I wanted to put it back in the SuperBooster box. Can you spot the pot inside?
