I think it's about time to show some of the stuff I've been working on ever since
I got infected with that DIY fever... :^)
Since my home has been waiting for an internet connection for 2 months now,
I did get plenty of time to get some builds done, some for friends, some for me personally...
This is a ROG splitter blend which I modified so you can also use it as a buffered A/B box
(either blend loop A with loop B or select between A and B, bypass is always functional)
I've custom build it for a friend who plays in Pirates and pitlizzards. (hence the crossbone theme..)
Inside pictures are found here:
http://www.anyplace.nl/pics/diy/sbab2.jpg(It's the first time I've etched a PCB and it turned out quite well! (notice the crossbone skull)
http://www.anyplace.nl/pics/diy/sbab3.jpgThis is my rehoused "build like a tank" Russian Big Muff with a EH LPB2 built in after the output
section. I highly recomend the LPB2 after the muff, it really opens up the sound and makes it
about 10x as versatile. (it can get unhealthy loud as well...) Also notice the really cool paintjob!
(hard to see but it's flat black paint "sputtered" over metallic dark grey)
http://www.anyplace.nl/pics/diy/bugmuff.jpghttp://www.anyplace.nl/pics/diy/bugmuff2.jpgThis is basically a ROG splitterblend modified to be a buffered ABY with a phase reversal
on the second channel. It's specific for some fender amps that have a "out of phase" second
channel and you want to use them both simultaneously.
http://www.anyplace.nl/pics/diy/aby.jpg
