that it is! a plastic cup hot glued to carboard. I just stick the box to it with a bit of looped tape.
Where did you get your drill press, and/or what brand/model is it?Also, same question, but about the drawer orgainzers. Thanks!
Quote from: deadastronaut on May 06, 2011, 05:45:29 AM@bruno...and the prize for the most tidy diyer goes too......... drumroll...................'bruno' erm...and perrow...(you'll have to share it..)
Ah, yes ! Those old testing instruments are true workhorses... And abuse-resistant !I also see that you have a similar "tube project chassis" as mine, but horizontal, wider, and probably with more features (and maybe a little onboard LV/HV supply).Here's mine - but I should improve it...A+!
Make sure you get some kind of dust extraction on that Rick, you don't want shiny boxes and a dull mind.Looks great, congratulations. Is it in the garden shed?N.B.Just an old hoover should do the trick if you can find one with the right filters.
My tube project chassis has been somewhat replaced with this, although this is moreof a tube tester than a project box. with it, I can still model different circuits withany kind of twin triode noval or octal...
Quote from: tubelectron on May 20, 2011, 04:08:17 PMAh, yes ! Those old testing instruments are true workhorses... And abuse-resistant !My tube project chassis has been somewhat replaced with this, although this is moreof a tube tester than a project box. with it, I can still model different circuits withany kind of twin triode noval or octal...Could you share the schematic for your tube tester/project box? It looks like a good project for this winter...Jaz
