Author Topic: Anybody build their Gristleizer yet, comments on it?  (Read 205644 times)
eeliyx
Re: Anybody build their Gristleizer yet, comments on it?
« Reply #460 on: August 18, 2019, 04:25:02 PM »
Could you post a picture of your PCB and wiring?
Is your MAX1044 outputting negative 9v at pin 5?
Here are the voltages of pins 1 to 8:
9.03, 5.4, 0, -3.27, -8.37, 4.36, 5.72, 9.04
Can you check with a continuity meter that the negative terminal of your power supply is connected to GND on the PCB, your enclosure, and the sleeves on your 1/4" jacks?
From what I tested, it's all connected to ground. The output jack it grounded through the case.
I contacted the seller about the pinout of the 2N3819 I was sent because I found conflicting information online.
Gonna test if the voltage at the charge pump changes when I turn up the depth next.
eeliyx
« Reply #461 on: August 21, 2019, 01:30:20 PM »
After some more days of testing I'm still none the wiser.
Can someone give me some keywords to research about the kind of oscillator used in this circuit and how the different waveforms are achieved?
If anything, this whole ordeal made me really want to understand Opamps in detail.
pinkjimiphoton
« Reply #462 on: August 21, 2019, 01:47:53 PM »
sounds like the switching to me, too... but at least for testing purposes, you need a ground on the output jack or nothing is gonna work right. even in the case, it may not be grounding the output. even tho it SHOULD ground thru the enclosure, it doesn't mean it always does. and without the ground to the output, the circuit can't possibly work right.
still thinking its working above the audio range, maybe a pot or two are oriented backwards?
Slava Ukraini!
~Jack Darr
Taylor
  • Total likes: 79
  • The clean energy source of the future.
« Reply #463 on: August 22, 2019, 12:57:28 AM »
I'm not sure the right name for this kind of oscillator, but the two opamp stages on the bottom left of the schematic are the actual oscillator, and the one on the bottom right is the waveshaper that creates the different waveforms. The way the schem is drawn makes it really hard to follow what the actual waveshaper stage looks like in any one configuration. If I have time I would like to redraw that section as four separate images so we can all see more clearly how it works at each switch position.
It's also been almost 10 years since I built mine, and I don't have it anymore, so some of the details have slipped my mind!  :icon_wink: As the Dudeist Monk above says, for now I'd recommend running a ground wire to your output jack just to be sure. If I haven't posted some new schematic images here in a few days, please feel free to bump the thread to remind me.
eeliyx
« Reply #464 on: August 22, 2019, 04:08:17 AM »
For anyone who wants to play around with a circuit model, I built the LFO stage in this online circuit sim.
https://falstad.com/circuit/circuitjs.html
Just save this as a txt and open it in the online applet.
« Last Edit: August 23, 2019, 01:36:36 PM by eeliyx »
« Reply #465 on: August 22, 2019, 10:54:47 AM »
the two oppie osc is a schmitt trigger/integrator type. plenty on that config hereabouts ....
telebiker
« Reply #466 on: August 22, 2019, 01:19:28 PM »
This page is no longer available. It has either expired, been removed by its creator, or removed by one of the Pastebin staff.
telebiker
« Reply #467 on: August 23, 2019, 08:06:40 PM »
I'm curious, has anyone faced up to the issue when the effect has hi-freq hissing noise while on? It's loud enough to be clearly hearable, however, the wet signal is louder and also very clear. And hissing increases when something exists in the input jack.
« Last Edit: August 23, 2019, 08:21:28 PM by telebiker »
telebiker
« Reply #468 on: August 29, 2019, 08:35:09 AM »
Can it be grounding problem? :)
Chahmann
« Reply #469 on: October 17, 2019, 04:17:27 PM »
Hi everyone, first time posting here, I recently built my Gristleizer and am having trouble with it... everything works fine except the definition of the different waveshapes and the depth (let me clear out that the depth pot works fine, but the actual depth is not that deep, on max itīs pretty mellow)... i think the rotary switch may have something to do with it, and the fact that i used an NTE451 instead of the suggested 2n3819, the pinout is different, thats fine, i managed to solder it the required orientation, BUT i noticed the current draw is 30 mA instead of 50, dont know if that affects. Also in "filter mode" it produces a very high pitched low volume hiss kind of noise,  and also noticed that the -9 volt pin on the MAX1044 outputs arund 7 volts instead of the same value of the positive... everything seems to be working except that it doesnt sound as deep as the videos ive seen... i will post a picture later tonight for you tu see... i hope i can get help here, Thanks in advance
-Chali Hahmann
Taylor
  • Total likes: 79
« Reply #470 on: October 17, 2019, 04:46:13 PM »
I would recommend using the 2n3819. Because this circuit uses the JFET in its narrow linear region rather than as a switch, the specific device characteristics do make a difference in the modulation results, so the lack of depth seems to point to that.
Regarding the high pitch noise, check that the MAX1044's pins 1 and 8 are connected to each other with a continuity meter. The chip has a frequency boost feature that sets the switching frequency above audio range, but if they're not connected it would be audible.
Chahmann
« Reply #471 on: October 17, 2019, 06:14:17 PM »
Thanks a lot mate, will check and probably come back for revision.... Ugh, gotta look for or order that 2n3819...as for the max1044, i hope it is what you said....aaand the rotary switch i think thereīs something going on there, anyways , Iīll be back. Cheers
-Chali
Chahmann
« Reply #472 on: October 18, 2019, 05:32:26 PM »
as mentioned before here are the images, cant take a pic of the frontside of the board caue the leds are glued in place so they act as mounts... if you can spot any mistakes please tell, thanks in advance
-Chali
telebiker
« Reply #473 on: October 18, 2019, 05:49:18 PM »
What a nice enclosure.
pinkjimiphoton
« Reply #474 on: October 21, 2019, 04:36:41 PM »
now mine don't @#$%in work ;)
ain't life grande? lmao
Slava Ukraini!
~Jack Darr
telebiker
« Reply #475 on: December 01, 2019, 02:10:45 PM »
Checked MAX1044's pins 1 and 8 and they are connected. Just wondering, what else can cause hi-freq hissing noise?
telebiker
« Reply #476 on: December 09, 2019, 09:59:03 AM »
Hello everyone! Want to fix this issue with high pitch noise. Do you think that it's worth to change potentiometers and ICs?
BetterOffShred
« Reply #477 on: December 09, 2019, 01:53:12 PM »
Make sure your 1044 I'd the scpa variety. Needs the "s" or they will make high pitched whine in audio devices
telebiker
« Reply #478 on: December 10, 2019, 03:55:58 PM »
Didn't know that. Mine is cpa only. However, not sure, where to find MAX1044SCPA. Is it possible to use TC1044SCPA or ICL7660SCPA instead?
« Last Edit: December 10, 2019, 04:24:17 PM by telebiker »
« Reply #479 on: December 11, 2019, 04:02:28 AM »
Yes.
