Cheers, I haven't used smoothing caps on this. What I meant was I assumed the triangle was the quietest wave, because a square wave drone box I made, has a teaingle setting, which is quieter, due to the smoothing caps used to create that shape. Hopefully I can get that gnarly distortion back. Then I can box it up. Initially it worked like a distortion/fuzz with no modulation, I swapped out the jfet,as advised by Taylor (thank you) now I've lost that lovely TG growl. I'm hoping it's because I've socketed the transistors and they're not seated right, a problem with the sockets I used. Maybe fold up the excess on each leg, giving more surface area, holding them closer to the board, or just hardwire them.Ivevjusr rebuilt a Teisco, the same as Cosey used, I ran it through a Tube Screamer and DS1, (clones) then parallel through a matrix mixer into a Univox, £20 nano fuzz and an unshaven fuzz, feeding them all into a bucket brigade, then tremolo. Slug Bait and Hamburger Lady, it was like she was in the room, going to through some reverb at it today.
