Ah! Excellent! That fixed my buzz slash tick problem. I dunno what I was thinking, I totally misinterpreted the schematic and had the ldr/led combo wired in all wonky.
Got another problem now though... If I have the rate led in, the led in the makeshift vactrol doesn't light up at all... Like the rate one saps all the current maybe?
@ ratbones .that shouldnt happen, i made the stereo version, and both leds(vactrols) light up fine, and the
3mm rate led....no problem...
are you using standard red leds...not superbrights?...
@thehoi. havent had any problems like this....put both 5mm led in and the rate 3mm in then turn it on ok....should be fine.
never had to use a resistor...are you using batteries or a psu..make sure its 9v only ok...
@pantufla. i havent built this version no....maybe perrow has?
?....mines still on a spare breadboard at the moment...
maybe you should look at the tiny stereo pannerversion too..dual tremolo...panning left right etc..only another vactrol and 2 resistors...
but you have the choice of 2 trems..use it as a normal trem, or stereo in the studio/live etc...i tried it, sounds great
adds a dynamic movement to the sound especially on solos, or picking stuff......check it out....rob.
i uploaded a new video today of the tiny trem and stereo version....on breadboard still
i got a bit of clicking at first attempt.....so i stuck a 1000uf across the power supply..it was close at hand...cured..bit extreme but it worked..
http://www.youtube.com/user/100roberthenry#p/u/6/Hb0heYolcTc
