Author Topic: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO  (Read 364141 times)
MetalUpYerEye
Re: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
« Reply #180 on: November 05, 2010, 03:28:51 AM »
That would be me, sorry. I've been swamped with work and have multiple PCBs (including yours) on my desk that I haven't been able to get to the post office. I'll get them all out this weekend, I promise.
No worries! I was just wondering what was going on with it.  ;D
Thanks again for the PCB. I've got all my goodies together for this project. I picked up a CMOS 555, couple red LED's and a 'grab bag' of LDR's at radio shack. I think it had like 5 different LDR's in it. I had a little trouble tracking down a 47k pot so I went with a 50k but it shouldn't be a problem.
« Reply #181 on: November 05, 2010, 03:53:48 AM »
Hey deadastronaut, could I bother you to repost that colorsound wah breadboard layout again? I tried building it from the schematic and must have done something goofy... Thanks!
@ratbones .its on page 8...i havent done this myself yet though...so its not a verified layout,....yet!.
if in doubt find the schematic and check ok....
@all. hmmm..so the led debate is still in the air then...hmmm...
i read that some use yellow,green and red for various projects also...!!!...
i know if i shine a superbright blue into an ldr it works though...on a wah,..(crap nurse quacky).
it opens right up..in daylight with no wrap... :icon_mrgreen: so theyre great for testing at least...
tuckster
« Reply #182 on: November 05, 2010, 08:45:33 AM »
Why do all my LED burn out if I don't use a series resistor? You don't use wann either.
« Reply #183 on: November 05, 2010, 08:49:06 AM »
no idea..mines ok...
i havent measured the voltages off the 555 to the leds...
pie-key
« Reply #184 on: November 05, 2010, 10:50:08 AM »
how about some BULBS?
i think they can make dramatic slow light ON/OFF sequence.... don't you think?
well ill go back to the lab now...
« Reply #185 on: November 05, 2010, 11:47:33 AM »
do you want mood lighting inside it... :icon_mrgreen:
a chill out lounge for a 555..... :icon_mrgreen:
seriously...id stick with leds...
Ratbones
« Reply #186 on: November 05, 2010, 04:45:49 PM »
Weird, I found the post I had seen it in before on pg 8 but it's not showing up for me now for some reason...
Ratbones
« Reply #187 on: November 08, 2010, 07:26:49 PM »
Turns out my goofy antivirus was blocking it for some reason. I breadboarded it following your layout but didn't have some of the necessary cap values.
And... It didn't work. Dunno if it was my substituting, or the layout though.
I did manage to get it working using the optochopto schematic though. It sounds really cool. Now I'm working on a triangle or saw wave lfo so it sounds more perty.
« Reply #188 on: November 09, 2010, 03:33:57 AM »
hi man, just breaded the wah, from schematic, not the breadboard i posted though!..all works fine
am messing with values on it today..and all the available mods..to try out...might add  buffer/boost on it..
as for the beavis optochopto, yeah that looks good, lets hear a sample when your done..sounds a cool idea..
MetalUpYerEye
« Reply #189 on: November 12, 2010, 05:24:15 PM »
I perf boarded this baby and can't get it to do anything for me. I used one side of a 556 timer. When I turn it on both LED's flash on for a split second and then turn off.
I built the version with signal and power grounds connected, input jack to turn it on, with a dpdt footswitch turning off the LDR and my rate LED (as an indicator) for bypass. I get the clean guitar signal but no LED's and hence no tremolo effect... Changing the pots has no effect either.
Any ideas? I need to check the voltage coming off the output of the 556 I think...
Earthscum
« Reply #190 on: November 12, 2010, 05:42:25 PM »
Same thing I get. Try increasing the resistor and pot by 10x and decreasing the cap by 10x... haven't tried it yet, myself. Should take a bit of the load off the chip, but your LED may not work. If so, try increasing your resistance by, say 2 times, and decrease your cap by 2 times, or 3x, etc. Just make sure whatever factor you increase the resistors, to decrease the cap by the same factor. This will keep it running like it should, timing wise.
MetalUpYerEye
« Reply #191 on: November 12, 2010, 08:33:01 PM »
I'm not getting any voltage on the output of the 556... For some reason the LED's will flash on for a second if I connect my input signal to ground... Not sure what I screwed up here...  ???
MetalUpYerEye
« Reply #192 on: November 15, 2010, 11:36:24 AM »
I have 9v to Vcc on my 556 but no voltage coming off the output of the chip. Any ideas?
« Reply #193 on: November 15, 2010, 12:09:06 PM »
hmmm strange, check the schematic on page 3...sounds like somethings wrong there..
i take it you havent got a 555..so are using one side of a 556..should be ok, just double check the pin connections though!.
knealebrown
« Reply #194 on: November 15, 2010, 04:34:52 PM »
so maplin sells LDR's in varying resistance bands,  which do u recommend?
http://www.maplin.co.uk/Module.aspx?ModuleNo=35962
i know i should be doing my uni work but this is so simple i can pick up the parts on my way home and have some 'me time'  ;)
''99 problems but a glitch aint one!''
MetalUpYerEye
« Reply #195 on: November 15, 2010, 06:50:04 PM »
Yeah something funky is going on. I built it per the schematic since I used a 556 instead of a 555, so the board and vero layouts wouldn't do me any good anyway. Everything seems to be in order but it seems like both sides of my LEDs are connected to ground. I get 9v from Vcc of the 556 to either leg on both LEDs... I must be missing something here...
I built mine on perf... Could someone post a drawing with all the pot and switch connections minus the inline/bleed switch please?  :-\
tombola
« Reply #196 on: November 15, 2010, 09:17:41 PM »
Beautiful design Deadastronaut, so simple. Love the way it's bidirectional - you don't need to label In and Out, because it doesn't matter which you use.
Only problem I have is with quite noticeable ticking. I built it with two grounds - checked with the meter, there's no connection between battery ground and audio ground. Have a 100uf cap between +9v and (power) ground. I've tried it with two adaptors and a 9v battery, different guitars, different amps. It's there when depth is at zero - i.e. the LDR isn't bleeding anything to ground.
Is there anything else I can try? Thanks!
Earthscum
« Reply #197 on: November 15, 2010, 10:08:19 PM »
I figured out with other oscillators (I can't get a 555 to do anything for me, so I cheat  ;) ) that it's basically sending a quick spike to the LED when it switches on. I tried RC network that seemed to work pretty decent at suppressing the spikes, one that seemed to work fairly decent was just a 47uF between the output and the diode. That was working on a CMOS 40106 oscillator, but wouldn't work for crap (at least the way I had it plugged together) with the MV-52.
Barcode80
« Reply #198 on: November 15, 2010, 10:12:34 PM »
if you are using a current limiting resistor, try increasing the resistor. Also, try moving your board around and see if it still happens. Sometimes proximity can cause bleed over.
Re: tiny tremoloooooooooo00000 now with 3in1.....
« Reply #199 on: November 16, 2010, 04:23:28 AM »
hi kneale, i went with the n46ay's....ive had a few different ones though and there didnt seem much different in the response...
@metalupyaeye. both led legs to ground...have you got a breadboard?, i would sort this out on there first...
@tombola, yes i stuck a 1000uf across 9v - and it was silent, extreme i know but it worked and was quick to grab from a pile of bits
..maybe try a 220/470..!!!!!..or do what barcode recommends.
@earthscum, yeah the 40106 should be ok, as in beavis optochopto...check it out everyone...its an alternative...
anyway,hi guys . ive been a busy little bee again, and finally got round to combining the colorsound wah with the tiny trem,
into one unit/pedal design.. it will be a 3 in 1 pedal with 2 toggle switches, so you will have
wah, trem ,and a tremwah....switchable.....i kind of like the wah as a non treadle filter type thing..and its great with the trem too..quackolo.. :icon_mrgreen:
the only problem i can see is running both off the same dc socket, anyone got any idea if this would be a problem?.....................
@perrow, your going to be busy with this pcb layout... :icon_mrgreen: :icon_mrgreen: :icon_mrgreen:
but it would be nice to have this on pcb, as the vero is understandably wide due to my veroing skills..(wheres adriano the master vero shrinker demon?.).
heres the idea..messy i know, was up late doing it... :icon_wink:
here ya go...
basically i glued a wah to the trem with a couple of toggles................ :icon_mrgreen:
any ideas, advice, any faults you can see...???????.....
« Last Edit: November 16, 2010, 05:22:56 AM by deadastronaut »
