LM3086 Fuzz Face?
Started by blooze_man, December 29, 2010, 05:42:22 AM
> Should be possible to find another usable transistor array that is still in production.
Pick-n-place robo-assembly and SMD has made single devices cheaper than multis.
DigiKey lists few through-hole arrays, all special and costly.
SSM2220PZ-ND SSM2220PZ IC TRANS PNP AUDIO DUAL 8DIP - Analog Devices Inc 2 PNP (Dual) 20mA 36V 100mV @ 100µA, 1mA - - - 190MHz Through Hole  8-DIP (0.300", 7.62mm)  Tube 465 1 7.16000
MAT03FHZ-ND MAT03FHZ IC TRANS DUAL MATCHED PNP TO78-6 - Analog Devices Inc 2 PNP (Dual) 20mA 36V 100mV @ 100µA, 1mA - - 500mW 190MHz Through Hole  TO-78-6 Metal Can Tube 1,216 1 15.61000
MAT01AHZ-ND MAT01AHZ IC TRANS DUAL MATCHED NPN TO-78 - Analog Devices Inc 2 NPN (Dual) 25mA 45V 800mV @ 1mA, 10mA 300nA - 500mW 450MHz Through Hole  TO-78-6 Metal Can Tray 19 1
Non-Stock  17.85000
MAT03EH-ND  MAT03EH IC TRANS DUAL MATCHED PNP TO78-6 - Analog Devices Inc 2 PNP (Dual) 20mA 36V 100mV @ 100µA, 1mA - - 500mW 190MHz Through Hole  TO-78-6 Metal Can Tube 15 13
Non-Stock  26.22231
MAT03EHZ-ND MAT03EHZ IC TRANS DUAL MATCHED PNP TO78-6 - Analog Devices Inc 2 PNP (Dual) 20mA 36V 100mV @ 100µA, 1mA - - 500mW 190MHz Through Hole  TO-78-6 Metal Can Tube 54 1 26.81000
Dragonfly
I'm not sure why you would feel the need to find a "modern alternative" when NOS CA3086's are inexpensive and readily available. Contrary to what has been said, they aren't "tough to find" at all.
You can buy CA3086's for $1 each + shipping ($4.95 + 0.25 each additional - but I'm sure in large quantities you could negotiate flat shipping).
Of course you could just get a surplus parts finder to sell you some - Ralphs shows them for $.47 each. It shows that they have a qty of one, but likely that that is just for the website - you could always call and find out.
ABRA has them at $.89 each ...I'm sure you could get a qty discount.
You can just put in a "bid" for whatever qty you need at USBID.
Or, you could just contact Mammoth - they show them at $2 each with an available qty of 498, but I'm sure you could negotiate a qty discount.
Of course the "old standby", Futurlec, shows them at $.79 each, but has a discount to $.70 in quantities of 25 and $65 each in quantities of 100. For larger order discounts, contact them.
nocentelli
Quote from: R.G. on December 30, 2010, 10:33:34 AM
There was one boutique repro of the big muff that used a transistor array chip
Way Huge Swollen Pickle?
roseblood11
to be true, I think that the whole idea isn´t interesting for most fuzz circuits.
If I had to make a larger number of Superfuzz workalikes, the 3086 really would make things easier, because of the matched transistor pair for the octave.
But for a simple Big Muff etc? I can´t see any advantage.
In a Fuzz Face, it´s interesting to play around with different transistor, and the best sounding pedals have transistors with different hfe´s, so maybe a 3086 wouldn´t be a good choice...
