Hi all!
Friends, you are giving too much emphasis on VCO LM311 … There are more important conditions MN3x07 management. In datasheet on these chips specified Clock Pulse Waveforms CP1 and CP2:
MN3007 MN3207
From the datasheet that the clock cross point (Vx) CP1/CP2 MN3007 for should be based not below 3 volts, and 1.7 volts MN3207 not above GND level.
When generating speed through triggers (4013, etc.), the clock cross point has a level 1/2 Vdd means BBD works not in an optimal mode.
A few years ago, I experimented, and compared the treatment of clocking by using MN3102 and 4013. At high frequencies (above ~ 500 kHz) S/N output 3207 in "trigger" mode was markedly worse than in regular mode. In addition, the output level was less than ~1.5-2 dB. This is because the principle of BBD.
I recently made new measurements of clocks, MN3207 clearly visible delay fronts phased impulses. The delay time is absolutely does not depend on the frequency. Photo taken on my Takwey DST1202.
Vdd = 9V. CP1 showing in yellow, CP2 shown in blue:
Waveforms at 53.29 kHz. Delay front 140 ns.
Waveforms at 172.95 kHz. Delay front 140 ns.
Waveforms at 495.8 kHz. Delay front 140 ns.
Waveforms at 1.805 MHz. Delay front 140 ns.
Waveforms at 53.17 khz. Maximal amplitude of rectangular form.
Waveforms at 318.84 khz. Amplitude and waveform does not change.
Waveforms at 1.015 Mhz. Amplitude and waveform does not change.
Waveforms at 1.62 Mhz. Amplitude and shape of the wave is beginning to change.
Waveforms at 2.01 Mhz. Amplitude and shape wave greatly changed. Clearly expressed asymmetry phases.
As the experiments showed my MN3102 quite satisfactorily generates at frequencies up to 2 Mhz, 4 MHz frequency which corresponds to the comparator LM311. The MN3102 generates the necessary delay fronts. However, since the frequency of ~ 1.2 -1.5 MHz pulse form is not symmetric and strongly CPx tamed, and reminds the bell, rather than a rectangle.
Moreover, at such high frequencies MN3102 cannot provide fast charge input capacitance MN3207, which is used in most development flangers.
But if the output MN3102 to fix an additional buffer (4049) as in the diagram by Thomas from the first message, everything is great!
An even better result would be, if the buffer is 4049, and the special dual high-speed MOSFET driver type MIC4424, or similar. Such drivers I have few years apply in our developments on BBD.
Good luck to all! Igor (aka Valentinych).
P.S. Sorry for my bad English ...
