Zombie chorus with anti tick mod 1590b layout?..
Started by deadastronaut, May 07, 2012, 06:08:49 AM
Dylananto
Hi, I apologize if resurrected this topic because I have a doubt, following the pcb deadastronaut do not understand where to connect the LEDs, typically using a 2k2 resistance, but do not see it on the pcb, you must connect it to part with the resistance or c ' is possibility to connect it directly on the circuit?
Thank's :icon_wink:
wow that was a long time ago...
IIRC i just hooked it up via a resistor to the IC on the pcb yes...
however, it will blink, rather than pulse...
Dylananto
I'm buying all the components to build the pedal because I really like how it sounds (much like the Small Clone) and very intuitive as a project. What interests me is that the LED is on continuously, when the 9Volts attack to report that the pedal is on, I do not want to blink or pulse. It would be possible to know exactly how to connect the positive of the LED?
Thank's dedastronaut  :)
Quote from: deadastronaut on October 27, 2016, 08:42:13 AM
Dylananto
Quote from: deadastronaut on October 27, 2016, 11:59:21 AM
ahhh..so you mean how to wire up a 3pdt switch + led...?
http://www.diystompboxes.com/smfforum/index.php?topic=113305.msg1048675#msg1048675
Hello deadastronaut excuse the delay in answering. I wanted to know how to connect the LED to the 3PDT switch, now everything is solved, I just put the LED light on and just, nothing led to 3PDT
Thank you so much from Italy ;)
Perrow
Dylananto
Hello, I finished building my small clone but I have a problem when I tried running you will hear a ticking noise type, just touch the strings of the guitar you hear this ticking and you can barely hear the little sound in the amplifier. I have done many tests, I unsoldered all wires from the switch 3dpt, I connected all direct co 9v battery, but nothing, it always makes the same sound, touch the strings and you hear this annoying ticking. I even double-checked overalls tracks and welds one by one but it looks okay. What could it be? I am so disappointed and angry :(
Dylananto
I can't solve the problem, no one can help me? Deadastronaut can you help me?
Cozybuilder
I incorporated a couple of fixes on my Zombie build, and got rid of the ticks. Here is the Schematic I used:
Note the mods in blue ink: there are two reference voltages, a capacitor in the flashing LED circuit, and a pair of caps at the oscillator IC power pin, literally right on the pin.
If I were to build another, I would change the power section: use a 1N5817 reverse polarity protection diode (rather than the BS250), then a series 47R resistor followed with 100uF and 100nF (ceramic) to ground for better supply filtering. This gives a knee at about 32Hz, getting rid of 50 cycle and above hum.
Dylananto
Quote from: Cozybuilder on December 13, 2016, 09:54:26 AM
Hi Cozybuilder, thank's for the your reply. You could post some pictures of the pcb?
This is the circuit that I have followed taking it from page 2 of this thread:
https://dl.dropboxusercontent.com/u/7464107/smallcloneclone.jpg
Cozybuilder
I don't know if my build will help, as it was done on perf, not PCB.
Dylananto
Thanks but this is not of great help to me, still very beautiful your stompbox :icon_wink:
Wow,  a chorus in that small box.
The "can do" attitude of you guys never ceases to amaze me!
Quote from: Rob Strand on December 13, 2016, 04:11:07 PM
Yep, those guys at IBM drawing corporate logos out of individual atoms just don't come close...   ;)
(Thanks for reminding us mere mortals of your microscopic insanity, Russ!)
mgsrake
Dear Cozy,
thanks for sharing your knowledge, I was reading your post and as soon as possible il try to apply it to my build too :)
What kind of capacitor are you using? None of those are electrolytic?
thanks in advance :)
bloxstompboxes
Quote from: mgsrake on December 19, 2016, 11:11:12 AM
Dear Cozy,
He is using what looks to me to be monolithic and tantalum caps. The tants are indeed electrolytic and will have polarity.
Cozybuilder
Poly: C1(Tayda box), C5 (Wima- Mouser)
Ceramic: C2, C3, C4, C6, C7, C8, C9, C11, C13 and U3 pin8 (100pF): 2 types- 2.54mm lead spacing (Mouser) & MLCC (5mm lead spacing- Tayda)
Tantalum: C10, C12, C14, C15 and U3 pin 8 (22uF) (from Tayda)
You left out the make and model of electron microscope, Russ...   ;)
Dylananto
Ok problem solved! They were not of good welds, now works great! Chorus Chorus Chorus ;D
If you tell me how to insert photos I post here. Thank you all ;)
