Author Topic: X FUZZ  (Read 150926 times)
bluesdevil
Re: X FUZZ
« Reply #360 on: July 29, 2014, 05:03:24 PM »
I'm pretty sure I got the transistors in correctly, but I'll double check.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
WhiskeyMadeMeDoIt
Re: X FUZZ
« Reply #361 on: July 29, 2014, 05:26:29 PM »
Bluesdevil if you want to reduce some of the circuitry I would just make the xfuzz clipper section and skip the dual clipper setup. It doesn't add much but it does make the circuit lots more complicated. Be sure to try the dual output though it gives you a lot of sonic possibility.
bluesdevil
Re: X FUZZ
« Reply #362 on: July 29, 2014, 05:55:46 PM »
Thanks Whiskey, I haven't tried the dual output stages yet..... will give it a whirl.
Just noticed you have the 3rd stage biased differently than the original I'm working from. Do I need to change it to work with new 4th stage?
« Last Edit: July 29, 2014, 07:13:02 PM by bluesdevil »
Cozybuilder
Re: X FUZZ
« Reply #363 on: August 22, 2014, 09:17:20 PM »
Heres my X-Fire 1590A build. This one has both fuzz stages, the X-rock side is modified to use 2 pink LEDs with 470K resistor and 470nF cap, wired similar to the x-Fuzz clipper. The input caps are the same, both clipper sections use the same 1 uF coupling cap after Q1. EF Q3 isolates the tone circuit, instead of the presence pot a fixed 51K is connected to ground, the rest of the tone circuit is the same- it works very well. Only the first output stage is used- not enough room to put in both in this box- although I might try again with ⅛ Watt resistors.. It sounds great, a superb design.
akc1973
Re: X FUZZ
« Reply #364 on: October 18, 2014, 03:47:17 AM »
i ended up tinkering with Gus's ASDF  a bit, and went for a more heavy type groove :icon_twisted:.......
cleans up nice too 8)
i used a pregain as i just prefer the control of that...
cheers for the inspiration gus....lots of tweaking fun to be had.
https://www.youtube.com/watch?v=kaBkdysrX_A&feature=youtu.be
well worth breadboarding..if only to annoy your neighbours.  :icon_twisted:
edit:
vero layout...something for the weekend.. ;)
oops left off the 100uf cap...like i say breadboard it first... ;)
Hey DA,
I just put together your x-fuzz using the layout at http://tagboardeffects.blogspot.com.au/2014/05/x-fuzz-by-deadastronaut.html and I bloody love it...so much fuzzy goodness...sounds great with my Rick copy...just gotta box it up now.
Thanks for your great work and keep it.... :D
akc1973
Builds: Bazz Fuss, Orange Squeezer, Omega, Green Ringer, Dist+, X-Fuzz
akc1973
Re: X FUZZ
« Reply #365 on: October 18, 2014, 03:48:36 AM »
...and, by the way, I used BC549s and they work great!
akc1973
Re: X FUZZ
« Reply #366 on: October 19, 2014, 03:26:46 PM »
cool... 8)
i still haven't boxed mine yet....been busy.. ::)
Re: X FUZZ
« Reply #367 on: September 30, 2015, 09:48:57 AM »
a friend sent me this link...
at least he put my name/s on the box..  ;)
http://tw.taobao.com/item/42737542984.htm
nick d
Re: X FUZZ
« Reply #368 on: September 30, 2015, 09:56:59 AM »
        Cost 399.00 meaningless squiggles - what's that in English ?
Re: X FUZZ
« Reply #369 on: September 30, 2015, 09:58:30 AM »
728,000,000... ;D
Re: X FUZZ
« Reply #370 on: September 30, 2015, 11:15:00 AM »
I think that's only about $63 US. A bit insulting for a DeadAstronaut design in my opinion! :P
Re: X FUZZ
« Reply #371 on: September 30, 2015, 11:17:43 AM »
 ;) 8)
Re: X FUZZ
« Reply #372 on: September 30, 2015, 11:34:55 AM »
that's 3.30$ per page. what's the going rate?
by request
Re: X FUZZ
« Reply #373 on: September 30, 2015, 11:38:57 AM »
$3.30 a page aint too bad for me really.....
Elijah-Baley
Re: X FUZZ
« Reply #374 on: December 07, 2015, 04:57:31 AM »
Nice one whiskey, hows the noise/hiss?
I wanted to follow up. On hunch and following the most logical idea that made the most sense, I assumed the hiss must be a product of the breadboarding etc. So... I did a quick 20x12 vero layout yesterday and formally soldered it up. Hiss gone and this thing sounds absolutely fabulous.  ;D She's going in a 1590B in the next few hours!
There may be a tiny mod there or so such as a 2n3904 for Q1 but otherwise it should be pretty much the exact same circuit. I'm going to make here a 4 knobber.
And another big thank you. This is strictly for my pedal board (hope it was ok to munge the name a little - was supposed to read space rock xfuzz but its a box in a day so...) and your moniker is on the bottom plate with full credit. I hope to go back and get it on the front but was in a hurry today because it's going with me to rehearsal in a couple hours. Anyway, thought I'd post the semi-final right as I was testing it:
Good job!
I would like build this effect, but the vero layouts I found is the 2 knobs version.
Can you share with us your vero layout?
I need the 4 knobs version (Pre-Gain, Volume, Tone, Bias).
Thanks! ;)
kzl666
Re: X FUZZ
« Reply #375 on: July 14, 2016, 10:54:14 AM »
Is anyone here? :icon_biggrin:
Can I introduce a standard big muff tone stack between last two stages without modifying any other components? Will it work properly? I'm not very good with schematics.
And what can be done with this "white noise" thing? The schematic is kinda "bigmuffy", and in big muff there's a little of that kind of noise, but somehow in this fuzz it's more apparent despite having less gain stages. Tried a 220pF (and even 470pF) cap on clipping diodes, it helped, but not a lot.
Re: X FUZZ
« Reply #376 on: July 15, 2016, 06:51:37 AM »
This should be the easiest try.. :icon_wink:
Although that BMΠ tonestack needs a 13dB gain "recovery" which I'm not sure if can be obtained by Q2 clipping amp...
Elijah-Baley
Re: X FUZZ
« Reply #377 on: July 15, 2016, 09:28:23 AM »
Here's my corrected layout:
I'm gonna use the Jdansti's layout ;). Waiting for Tayda's pack. ::)
First time for me with this kind of board, I usually use stripboard.
kzl666
Re: X FUZZ
« Reply #378 on: July 15, 2016, 09:37:14 AM »
For the last two stages I meant between Q2 and Q3. As I can see Q3 is basically the same recovery stage which can be found in big muff right after the tone stack. I've tried it already and something went wrong, it doesn't sound right (like in my big muff). Also, now that I have introduced that recovery stage (before there wasn't, just a plain simple schematic from the first page of this thread) "white noise" thing is just crazy and the sound is kinda gated. I've used KT3102E as Q3, maybe that's why. I need to rebuild it properly and use something like 2n5088 (somehow it's hard to find any decent transistors here, can't even buy something like BC546/547C).
DK1
Re: X FUZZ
« Reply #379 on: November 20, 2016, 09:46:38 PM »
 Built one with the tagboardeffects.blogspot.com vero layout. Sounds killer. I used a 57nf input cap.
Thank you.
