"Le Craquement Thermionique" !!
Started by frequencycentral, March 29, 2010, 01:21:53 PM
Quote from: phector2004 on April 22, 2010, 05:58:26 PM
can you drop that triode in to replace a tranny? (with re-biasing, of course!)
I don't understand the question.......
phector2004
sorry about that, didn't word it too well... i blame caffeine + lack of sleep!
Would a 7806 triode be a suitable replacement for a transistor? Or do they have a different function altogether?
NQbass7
Rick,
Where'd that superheated section come from?  I'm kinda curious what that does/how it works.
Quote from: NQbass7 on May 05, 2010, 03:25:36 PM
Rick,
Superheated SHO
BSIAB
NQbass7
*Doh*  I knew it looked familiar.  I actually even looked at the app note in the AN-32 datasheet that the mini-booster was based off of while trying to figure it out.
jbord39
#25
I am planning on building this pedal (the second version posted with superheated/hot setting) but was wondering if you could help me with a few questions.  The 7806 is going to be hard for me to come by, so would a 5.1V zener and .7V silicon diode in series to ground work; or should I just use an adjustable voltage regulator?
Also, would a 7V zener and 3x .7V silicon diodes work for the 9.1V zener?
I don't have the 2n5457; would any of these transistors work in its place?
2N5087
2N3906
2N3904
2N5089
J201 FET
Thanks,
John
Renegadrian
Quote from: jbord39 on May 30, 2010, 04:24:55 PM
2N5087
2N3906
2N3904
2N5089
J201 FET
Thanks,
John
J201s and 2N5457s are easily interchangeable...
You could use a 7805 with a 1n4148 between pin 2 and ground instead of the 7806. That would get you 6.2 volts.
Instead of the zener you could use red LED (as in the ROG Peppermill) or even a 1n418 (I believe?).
NQbass7
Quote from: NQbass7 on August 03, 2010, 09:32:41 AM
So how's it sound??
Just as I remember it. It's been a while since I breadboarded it. I'll get some clips up later this week.
I drilled four 5mm holes, used a 4mm round file to open them into a slot, then used a flat file to finish it.
therecordingart
Quote from: frequencycentral on August 03, 2010, 11:17:43 AM
Jesus. That cut looks so clean you'd think it was done by a CNC.
Slade
Hi,
I breadboarded this thing and found it was too gainy (too much fuzz like!) wit 1M grid leak resistor so I went down with the resistor until I found the best value to my taste: 100k.
This demos are made to show extreme settings of this pedal.
Both demos:
- Pentode Mode
- Godin Exit 22 Guitar -> Breadboard -> Yamaha F20 Amp -> SM57 -> Presonus Audiobox Interface->PC.
Demo 1: Hot Mode - Gain at Min - Moving Tone control from Min to Max
http://dl.dropbox.com/u/3565959/Le%20Craquement%20Clean%20-%20Tone.mp3
Demo 2: Superheated Mode - Gain at Max - Moving Tone Control from Min to Max
http://dl.dropbox.com/u/3565959/Le%20Craquement%20Max%20Gain%20-%20Tone.mp3
Regards,
Fernando.-
richon
excelent....
i liked the "low gain" mode more than the other, as with "max gain" it sounded to fuzzy...
nice demo!
why can't the god of tubes give me 2 tubes my mail?  :icon_mrgreen:  :icon_mrgreen:  :icon_mrgreen:  :icon_mrgreen:
wena Fernando!
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Slade
Quote from: richon on September 14, 2010, 08:54:27 AM
You have to keep praying.... in binary.
richon
01010010 01101001 01100011 01101000 01101111 01101110 00100000 01110111 01100001 01101110 01110100 01110011 00100000 01100001 00100000 01101101 01101001 01100011 01110010 01101111 00100000 01110100 01110101 01100010 01100101 00101100 00100000 01110000 01101100 01100101 01100001 01110011 01100101 00100001 00100001 00100001 00100001
"Richon want's a micro tube"
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Slade
Just finished this genius pedal.
I'm loving its versatility as it can go from a TOTALLY CLEAN tube sound to a harshy fuzz with a lot of gain and passing through great overdrive sounds!
I noted it was thought as an amp because it has a dual gain mode preamp, a dual pole tone control and an output tube that's being driven for those two things... Beautiful sound.
If anybody was asking about clean tube sound boost IT IS THE ONE. I was very happy with my modified THOR for its clean compressed sound until I tried this (not that Thor is a bad pedal, tough)
Thanks for your work, Rick, impressive pedal for such few components.
Pics!
Regards,
Fernando.-
