"Le Craquement Thermionique" !!
Started by frequencycentral, March 29, 2010, 01:21:53 PM
Slade
#60
Here's another thing I've just recorded with the pedal and my Flashback Delay Deluxe. I was looking for this kind of tone from a time now.. I'm so glad I built it!
I tried to play 'Mr. Oysterhead's solo (track 2 of The Grand Pecking Order album) ;D
Etchmaster fingers > Godin Exit 22 > Thermionique (at 9V) > Flashback Delay Deluxe > Yamaha F20 SS amp > Celestion Greenback 12" Speaker > SM57 > Presonus Audiobox > PC
:icon_mrgreen:
https://dl.dropbox.com/u/3565959/ThermoFlashback%20Tone.mp3
Cheers!
Govmnt_Lacky
Was revisiting this thread and found no answer to my question so I figured I would revive it!  ;D
Basically, the thread talks about putting 12V and 9V into the circuit however, I am wondering how it will handle >12VDC  ???
If I were to put over 12VDC (say 18V) would there be a problem?
I looked at datasheets for the 5840 tube however, I could not find any MAX voltage in values.
Anyone have an idea of the max headroom there is for this circuit?
juansolo
165V on the anode plate, 6.3V for the heaters.
I've run them at about 35-40V with a charge pump from a 12V supply.
Here's another of mine. This one was designed to run from 9 volts, and has a charge pump (the perf by the 3pdt) to supply just the tube with 18 volts, the MOSFET stage is running from 9 volts.
Govmnt_Lacky
Quote from: frequencycentral on March 16, 2011, 06:55:41 PM
Looks fantastic as ever Rick!  ;)
Would you mind sharing how you implemented the charge pump circuit? A layout possibly?
Thanks  ;D
The charge pump feeds the resistors at pins 5 and 7 of the 5840, instead of them being connected to the main +ve supply rail. TBH I've built that charge pump circuit so many times that I just perfed it up without a layout. Madbean's Road Rage PCB springs to mind if you wanna go that way. I've now designed a layout with the charge pump and the main circuit integrated onto the same PCB, but this is one of those rare occasions when I'm keeping it to myself, as I'm offering this pedal through my website.
Govmnt_Lacky
Quote from: frequencycentral on March 17, 2011, 01:57:58 PM
I completely understand this Rick. There is no justification needed because if it were not for you, there would be A LOT missing from this forum! You have contributed SO MUCH that there should be no need for explanations!
Thanks for the heads up on the charge pump idea. Off to the drawing board...  ;)
phector2004
Hey Rick,
What does it sound like with more voltage?
I think an on-off-on toggle or a rotary would be a cool addition to tack on diode-capacitor stages to the MAX1044. To bump the tube up from 9V --> 18V --> 36v, or something of the sort. Unless of course it gets the charge pump angry  :icon_eek:
Ben N
Quote from: Slade on September 20, 2010, 09:13:38 PM
:icon_mrgreen:
Cheers!
Wow, that sounds good! This is really a must-build.
Govmnt_Lacky
Any idea how much current this circuit is pulling?
I was wondering if a battery could be used  ???
OR.... would this circuit drain a battery quickly?
Slade
Only the heater works with 150mA, I think it's not a good choice to use batteries with this one.
Govmnt_Lacky
Quote from: Slade on March 21, 2011, 02:22:54 PM
Thanks Slade.
I would only need the 9V battery in case of emergency or loss of power from a wall wart or PS.
Just wondering if it could handle the load even for only 5 to 10 minutes.
Govmnt_Lacky
Has anyone tried using transistors OTHER THAN the BS170 and 2N5457 that the design calls for?
Got this built up yesterday and I really liked it's flexability and sound but I would like to try to "smooth it out" just a bit and I was wondering if other combinations of transistors sounded different and/or better  ;D
2N7000 is a replacement for the BS170 IIR (though the pinout is a mirror image). I guess most FETs would work in the 2n5457 position, I've got a Thermionic here with socketted trannies so I guess I should try some others.....
Govmnt_Lacky
Quote from: frequencycentral on March 23, 2011, 02:44:29 PM
Thanks Rick.  ;)
I fired this up last night and I do like the Pentode/Superheated mode (I used a DPDT switch instead of 2 SPDTs).
In the Triode/Hot mode it sounds more like a booster than an OD. I guess the OD is very subtle.
When in Pent/Superheated mode, the OD gets grainy and crackled at the top end of the pot. I would like to smooth it out.... hence the attempt at different transistors.
Spectacular design though!!  ;D
vendettav
thins thing looks freaking kickass!!!
gonna try and see if i can come up with any tubez
check my music HERE
Shredtastic psycho metal!
ACS
Quote from: Govmnt_Lacky on March 21, 2011, 02:30:21 PM
Thanks Slade.
Old question I know, but an alkaline 9V battery is around 550mAh, so you could expect 3ish hours of operation from a ne one at that current draw...
My tame shred master Rich Russell did me some soundclips: http://dl.dropbox.com/u/967492/Thermionic%20Montage.mp3
hobo_hephew
Really liked the soundclips you guys posted of this one, so I tried to build the craquement without the tone control yesterday, using the schematic below, but it crackles and sputter like crazy. So, did I remove too much/ too little, or does it somehow need re-biasing when the tone control is removed?
junlais
Hello this is my Thermionic, wonderfull diy project, Thanks Rick.
