OK, guys, I still need help on this one. I took some time off (well, not really "off", just changed projects and made some more pedals; I actually made the Engineer's Thumb Compressor, and a Deep Blue Delay clone, both of which are working wonderfully), but considering I have 2 of these boards built, and that neither one has worked, I wanted to get back to them and finally get one of these suckers to actually work. Plus, I could really use a Chorus on this pedal board:
Got 5 pedals working (technically, 6, but I do not like the sound of the 6th); one that is not. Not a terrible record, but lets make it better!By the way, both the Screechy Cat and the Vulcan Rat overdrives are getting a make over and will be done in 1590B size; I have a board for a Phaser that I will build soon, and between that one and this pedal, I
will need the space! I also ordered a kit to make custom length cables to neaten everything up a bit. I will not, however, use the old enclosure I made for the Little Angel because (1) I already used the same color for the Deep Blue Delay, and (2) I rather go smaller into the 1590B enclosure, but I will keep the same graphic style as the other one. I'll just probably go with a metallic violet color or something along those lines...
Old enclosureAnyway, where do I begin to check this darned pedal? As for the PT's, I tested them all in the Deep Blue Delay (when it was in BB form; I took that apart and actually built the pedal now), and they all worked. The issue is still that the dry signal goes through, but not the wet signal (I get no chorus effect).
Here are my voltages:
Battery: 9.20V
TL082:
1: 4.68V
2: 4.68
3: 4.53V
4: 0V
5: 2.80 to 3.70V
6: 2.88 to 3.65V
7: 0 to 1.4V
8: 9.20V
78L05:
IN: 9.2V
GND: 0V
OUT: 5.01V
2N2222:
C: 0V
B: 0.449V
E: 2.43V
PT2399:
1: 5.01V
2: 2.5V
3: 0V
4: 0V
5: 3.40V (should be around 2.65V)
6: 2.43V (should be 0.61V)
7: 0.875V
8: 0.995V
9 to 16: around 2.5V with movements
