Author Topic: "Little Angel" - Super Simple PT2399 Mini Chorus  (Read 523136 times)
Pigyboy
« Reply #360 on: October 18, 2010, 06:50:53 AM »
If I even see the word 'vero' I break out in a rash :icon_eek:
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
« Reply #361 on: October 18, 2010, 06:55:44 AM »
 :icon_mrgreen:
http://www.youtube.com/user/100roberthenry
  • Poster2
  • Total likes: 119
    • frequencycentral
« Reply #362 on: October 18, 2010, 07:11:17 AM »
Y'know, I've started a few vero layouts (to benefit all mankind), I place half a dozen components then I think to myself "@#$% this @#$%ing mother@#$%er !! If people are 'individual' enough to want to use @#$%ing vero over a superior media they can just make their own @#$%ing vero layouts !!" I HATE vero with a vengence.
Pigyboy
« Reply #363 on: October 18, 2010, 07:14:54 AM »
Help us Renegadrian! You are our only hope....
                                                            - FANG
« Reply #364 on: October 18, 2010, 07:22:06 AM »
erm...perf? :icon_mrgreen: only joking..... 8)
i'll get my coat.......... ;)
« Last Edit: October 18, 2010, 08:10:56 AM by deadastronaut »
« Reply #366 on: October 18, 2010, 08:22:43 AM »
 :icon_mrgreen: funny...
rob has left the building....with his coat on.... :P
i'll  put this on here on mr slaves behalf...to cover his rash. :icon_mrgreen:
« Last Edit: October 18, 2010, 08:36:44 AM by deadastronaut »
Govmnt_Lacky
« Reply #367 on: October 18, 2010, 08:30:05 AM »
+1  ;D
for an amount of ‘up to and including my life.’
  • Poster2
  • Total likes: 119
    • frequencycentral
« Reply #369 on: October 19, 2010, 12:27:00 PM »
A guy over at FSB just posted a pretty neat looking vero layout (unverifed), I'm sure he won't mind if I post it here:
Pigyboy
« Reply #370 on: October 19, 2010, 02:37:01 PM »
FSB?
                                                            - FANG
BoxOfSnoo
« Reply #371 on: October 19, 2010, 02:41:34 PM »
FSB?
Either front-side bus if you're talking about a computer, or more likely the other DIY stompboxes forum whose name we don't mention :)
My Dropbox referral link - bonus 250MB of space for both of us if you use it
defaced
« Reply #372 on: October 19, 2010, 06:44:57 PM »
Free Stomp Boxes.org
-Mike
Pigyboy
« Reply #373 on: October 19, 2010, 09:34:45 PM »
Thanks guys,
Acronyms and politics are not my strong suit :-X
                                                            - FANG
Pakaloabob
« Reply #374 on: October 24, 2010, 08:34:45 PM »
I am having a little trouble with this circuit on the breadboard. It seems that my supply voltage, which is 9v volts from a One Spot power supply, drops down to 6.3v. I believe I have located the issue to be the 78L05 regulator. The one I am using is to-92 package and I am using the PCB layout as a guide for hooking it up.
Anyone have a suggestion to correct my problem. I am seriously excited to try this circuit as soon as I get past this issue.
Barcode80
« Reply #375 on: October 24, 2010, 10:26:10 PM »
I'm confused. the 78L05 should drop the 9 volts down to 5 (or 6 with tolerances). Am I misunderstanding your question?
Pakaloabob
« Reply #376 on: October 24, 2010, 11:03:14 PM »
Yes, the regulator does drop the voltage it outputs to 5 volts, but when it is in the circuit, my supply voltage to the rest of the circuit  drops down to about 6.3v. That means that the voltage fed to pin 8 of the dual op-amp (NE5532 in my case) is only at 6.3 volts when it should be 9. In addition, the voltage fed to the non-inverting input on one side of the op-amp is also not what it should be.
Something is pulling my voltage down, but I can't quite figure out what it is. When I remove the 78L05, the supply voltage is back to 9 volts, when the regulator is in the circuit, it reads 6.3v. I have tried another regulator and also another PT2399 with the same results.
I just thought someone might have had a similar issue, or be able to point me in the right direction.
Govmnt_Lacky
« Reply #377 on: October 25, 2010, 11:43:46 AM »
Sounds like you need to start checking resistor values and solder bridges on or around your voltage regulator. R1 shorted to the ground post of the regulator?
Good Luck  ;D
Pakaloabob
« Reply #378 on: October 25, 2010, 08:06:43 PM »
Well, it turns out all I had to do was run the circuit off a battery instead of a power supply.  :icon_redface:
I really wish I knew why the power supply wasn't working properly for this circuit. If someone has any idea, I would love to hear. At any rate, things are working fine off the battery so I won't get too worked up.
« Reply #379 on: October 26, 2010, 03:30:16 AM »
just as a note : i had the very same problem with a 'zombie chorus' worked fine on a battery, but wouldnt 'chorus' on my psu...
i ended up having to put a regulator on the dc socket..and it worked fine...hope this helps....
