Author Topic: Building the Meat Sphere  (Read 196519 times)
idy
Re: Building the Meat Sphere
« Reply #640 on: January 27, 2021, 07:40:35 PM »
10.5k should not change things. That is an odd value though... Is that by color code or measuring? I guess they do make those....
telebiker
« Reply #641 on: January 27, 2021, 07:42:43 PM »
I have a bag of these 10.5k, so probably I soldered them instead of 10k since I don't have 10k...
telebiker
« Reply #642 on: January 27, 2021, 09:12:41 PM »
So I found some 10k resistors and replaced these which should be 10k, and I have the same results. Will get some LM358 and share results.
telebiker
« Reply #643 on: March 09, 2021, 07:26:03 PM »
Looks like LM358 fixed the issue, thanks for the help! The envelope appeared.
Now having issues with bypass wiring, probably I did something wrong, but instead of effect there is pretty loud noise when the effect is engaged.
idy
« Reply #644 on: March 09, 2021, 08:17:46 PM »
Congratulations on your functioning meatsphere.
Do you know how your bypass scheme is supposed to work?
telebiker
« Reply #645 on: March 10, 2021, 08:41:03 AM »
I'm using bypass scheme from the build doc and it is pretty straightforward.
The only thing which confuses me, in the build doc GND connection from power supply is not indicated as connected to the common ground. I also haven't wired a loop until I have working bypass.
idy
« Reply #646 on: March 10, 2021, 12:01:56 PM »
The Doc I see shows the DC jack going right to the board (both wires) and then tells you to ground all the jacks.
I attach them all to a lock washer (internal tooth, an extra from a foot switch) and add a jumper to the DC jack ground, and put this around there DC jack.
The jacks must be attached to the same ground as the circuit!
telebiker
« Reply #647 on: March 10, 2021, 06:58:08 PM »
For some reason my LED wiring was wrong. I decided to use PCB slot for the LED and it worked finally. Will post some pictures once it is boxed.
Thanks again, Idy, I own you a beer :)
idy
« Reply #648 on: March 10, 2021, 08:08:57 PM »
Wacka wacka. Hope you love it and use it.
I am big on adding a switch and buffer so you can blend in either send or return.... mixing a filtered fuzz with straight signal is bit of oil and water...mixing filtered fuzz with straight fuzz is phasey magic.
My next ambition is to add a phase switch to play with this blending... HP and LP are inverted.
telebiker
« Reply #649 on: March 16, 2021, 07:20:09 PM »
BTW, is there schematics for these mods? :)
Tried Meat Sphere with the Fuzz in the loop and it's so cool.
idy
« Reply #650 on: March 16, 2021, 11:30:07 PM »
No schematic but you can find simple strip board layouts for buffers (I used and IC, but BJT and FET work).
http://tagboardeffects.blogspot.com/2014/08/buffers.html
You pull the #1 terminal of the blend pot out of the board and attach it to the center of a SPDT switch. Wire the buffer input to the "return" jack and the output to one terminal of the switch and the other terminal to the hole you pulled the pot terminal out of.
The phase mod: (unverified) You use a buffer that also has a phase reverse switch. These are also out there on strip board.
idy
« Reply #651 on: March 16, 2021, 11:33:43 PM »
idy
« Reply #652 on: March 19, 2021, 02:07:15 AM »
The buffer with inverter would have to be after the switch...so it would invert the non-filtered signal from either send or return. Again, haven't tried it.
rectifierfx
« Reply #653 on: March 29, 2021, 05:17:43 AM »
Hi everyone,
I'm new to the boards. I joined after discovering musicpcb.com and the Meat Sphere. I've read this thread, and am excited to build my own! I'm a graphic designer by profession, so I enjoyed identically recreating the Lovetone Meatball pedal interface this morning. I used an overhead photo of the original pedal as an overlay, tracked down the typeface and got to work creating the vector art.
My template is designed for the pedal enclosure sold on eBay that closely resembles the original (I'm not associated with the seller). I plan to have the template cut into a vinyl to use as a spray stencil directly onto the pedal surface.
Below is a jpg preview. Awaiting my pedal enclosure so I confirm the specs before I can share. I'd be honored to share the actual PDF artwork with everyone here if they wish to do the same to theirs.
Cheers!
John
Can someone reupload the design ?
Seems like its not on photobucket anymore
KarenColumbo
« Reply #654 on: March 30, 2021, 01:04:05 PM »
As soon as this thread reaches 40 pages, I have to build a meat sphere. Fact.
“I want something that'll give me the stamina of a young werewolf, the vision of a shaman, the thoughts of a serial killer and the gentleness of a hungry vampire bat.” - Spider Jerusalem
rectifierfx
« Reply #655 on: March 30, 2021, 09:50:08 PM »
Nah you gonna build them all :icon_mrgreen: Much more fun. I got kinda addicted to Lovetone stuff. Got the doppelganger already. Wobulator in the bench. Cheese / Source PCB half populated. The only 2 I‘m missing is the Sting Ringer and the Flanger without a name
Marcos - Munky
« Reply #656 on: March 30, 2021, 10:14:12 PM »
Just commenting anything, to make my contribution for thread to reach 40 pages soon :icon_lol:
KarenColumbo
« Reply #657 on: March 31, 2021, 02:24:15 AM »
Wait! I didn't mean to ... ah ... damn!
« Reply #658 on: March 31, 2021, 06:32:19 AM »
Ooops.  Slipped.  My bad.   :icon_redface: :icon_rolleyes: ;D
« Reply #659 on: March 31, 2021, 09:37:02 AM »
I, also, need to keep up my bullshit posts quotient.
are we there yet?
"I think we're done here."
