ayayay!
QuoteMmm.. I can't say I'm a fan of that layout.. resitors standing like that, next to resistors flat
I think it looks great.  And if it sounds the same...
The people who work for a living are now outnumbered by those who vote for a living.
Manny
Damn Joao,
I can't get over how nice and tidy that board looks!  :D
jkokura
I think the standing resistors were so the layout could fit into a 125B box...
Jacob
phector2004
Galego, what exactly do you do to your resistors?
Do you bend a little notch to keep it in the hole? I hate dealing with upright resistors, but sometimes I need to do it  >:( I almost always end up with a resistor coming out at 45 degrees
Galego
Quote from: phector2004 on November 25, 2010, 12:56:43 PM
Here's a little how-to (bend first with pliers, then the second bend with your finger):
Galego
Quote from: Manny on November 25, 2010, 12:04:48 PM
Damn Joao,
Thanks :D
eniacmike
madbean's design goals for the sunking pcb was to make a klon pcb that could fit into a 1590B enclosure.
here is his build:
I was going to do that too but I wanted to make it look like the klon, and have room for a battery. I use a powersupply alot of the times but sometimes when you are doing showcase shows with quick turnarounds you don't have time to run power up for a 15 minute set, so I like to have the option.
by the way the build doc calls for 1/4 watt resistors not 1/8th. it is designed for standing resistors.
I don't have any problem with standing resistors. height is usually never a problem because they are shorter than caps or ic's with a socket and size of the board is always an issue.
phector2004
Quote from: Galego on November 25, 2010, 03:51:53 PM
Gonna try that out sometime soon  :)
bean
Generally I like to avoid standing resistors when possible, but it's just unavoidable in certain situations (like when you are trying to fit 80+ components on less than 2" sq.). Personally, I never use 1/8W resistors, mostly because my bench is completely stocked with 1/4W (geez, like tens of thousands of them now).
Actually, the thing I like least in PCB layouts is jumpers...I will spend hours trying to design around them. Fortunately, double sided boards eases the pain a bit.
Nice build, Mike :)
darron
Quote from: eniacmike on November 25, 2010, 06:37:59 PM
are they the tiny 2.1mm jacks? i just saw one the other day. how do you find them and where do you get them? (:
tuckster
#14470
Quote from: darron on November 26, 2010, 01:08:56 AM
Maybe these?
http://www.lumberg.com/main/common/produkt_fs.asp?lang=eng&produktname=1614_09&wg=016&cat=4&newWin=1
Farnell/Element14 sells them au.element14.com search for "Lumberg 1614 09"
Sorry I'm not familiar with Australian shops.
I buy them here: http://www.musikding.de/product_info.php/info/p2097_DC-power-jack-2-1mm-Lumberg.html
pete27
Built these two the other day, GGG orange squeezer and tubescreamer
darron
Quote from: tuckster on November 26, 2010, 02:08:02 AM
Maybe these?
I only saw one the other day and was interested by the amount of unshielded area they have compared to the usual. Id be interested in someone's feedback on them. I didn't realise they were unswitched with two terminals though...
@darron. i use those type, i get mine from bitsbox.co.uk..
nice n small. but im in the uk.  you might  be able to get them in oz..
@pete i like the spray job..nice. very citrus. :icon_wink:
tuckster
Oh sorry yes the Lumberg are unswitched. I never use batteries.
darron
Quote from: tuckster on November 26, 2010, 05:13:41 AM
that's thinking green (:
g.
G. Hoffman
Quote from: g. on November 25, 2010, 02:39:47 AM
Quote from: Kearns892 on November 24, 2010, 08:11:58 PM
Any chance you can let us know how you got the screws recessed? Was it as simple as a going slow with a steady hand or did you use any sort of tricks?
with this tool :
"Fraise d'encastrement de têtes de vis"in french, sorry i don't know the english name.
Those are OK, but I get much better results from drill point countersinks.  LOOK HERE, and scroll down to it.  You can use them to drill your hole, but I usually drill a pilot hole first, since they aren't great at clearing chips.
Gabriel
I like Grunge
tuckster
Violent Ram's Head Muff
With three clipping stages. Lot's of bass :o didn't recognise it while plaing on the breadboard  ???
http://www.diystompboxes.com/smfforum/index.php?topic=88132.0
