RG Keen Debugging checklist1.What does it do, not do, and sound like?
Constant crackling and can’t hear effect. When turned off (true bypass) all is well, so I don't think it's an off-board wiring issue.2.Name of the circuit = Little Angel Chorus
(VERO layout)3.Source of the circuit (URL of schematic or project) =
Vero Layout I used http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg737758#msg737758 Original layout/parts list http://www.diystompboxes.com/smfforum/index.php?topic=86297.msg723128#msg723128 4.Any modifications to the circuit?
N5.Any parts substitutions? If yes, list them.
no.
6.Positive ground to negative ground conversion?
Don’t knowVoltage readingsVoltage at the circuit board end of the red battery lead = 8.34
Voltage at the circuit board end of the black battery lead = 0
Q1 78L05
Out = 4.97
In = 7.94
Grnd =0.01
IC1 NE5332
P1 0 P4 0.01 P7 varies
P2 3.35 P5 varies P8 8.20
P3 2.93 P6 varies
IC2 PT2399
P1 4.97 P4 0.01 P7 3.23 P10 2.48 P13 2.48 P16 0.01
P2 2.47 P5 0.95 P8 3.28 P11 2.48 P14 2.48 P17
P3 0.01 P6 2.32 P9 0.27 P12 2.10 P15 0.08 P18
Z1 (zener)
A (anode, the non-band end) = 0.01
K (cathode, the banded end) = 8.12
Voltage on all Electrolytic caps is higher on (+) pin than on (-) pin
I have PCBs coming and will do a fresh build on them. Until then, I would love to get this working. Any help would be greatly appreciated, as I'm not a circuit design guy, but can follow directions and build.
Steve
