Author Topic: "Little Angel" - Super Simple PT2399 Mini Chorus  (Read 688969 times)
Pigyboy
Re: "Little Angel" - Super Simple PT2399 Mini Chorus
« Reply #700 on: July 31, 2011, 05:58:22 AM »
It will latch up sometimes with a straight jumper but seems to be all right with the 1.2k....I just want to hear it next to one with a 330k so hear the difference...gonna play around and post what I find.
And you'll have to admit, I'll be rich as shit
I'll just sit and grin, the money will roll right in....
                                                            - FANG
merlinb
« Reply #701 on: July 31, 2011, 05:59:56 AM »
Whatever is causing it to latch up, it isn't that resistor! It's completely unrelated to the PT.
Pigyboy
« Reply #702 on: July 31, 2011, 01:08:23 PM »
Ok, I changed C5 & C6 to .47uf film caps and it really cleaned everything up. I jumpered R7 - 330k and on mictesters pin 6 fix I changed R1 from 47R to 1R2 and R2 from 2K2 to 68K and it has not got hot or latched up. It still has some background but it is acceptable I think. I don't have any other chorusy type boxes here to compare it to...success!
                                                            - FANG
Pigyboy
« Reply #703 on: July 31, 2011, 01:30:39 PM »
Does this make sense...
I noticed when the PT latches up if I unplug it and short the +/- of the power jack then plug it back in it works every time. So I wired the red battery terminal lug of the power jack that I am not using to the ground lug. When the power jack is unplugged the + shorts to the - and resets the chip...seems to work everytime...this is using mictesters pin 6 fix set-up on the 1590A build.
                                                            - FANG
Pigyboy
« Reply #704 on: July 31, 2011, 01:51:03 PM »
While I am thinking about it I recall people having problems with the sound being distorted or farty...I am pretty sure if you change C5 &C6 to .47uf film caps it will fix this. I have one here that sounded shite with ceramic .1's and totally cleaned up with the change. Hope this helps...
                                                            - FANG
merlinb
« Reply #705 on: July 31, 2011, 05:39:41 PM »
Yes that would make sense. Mictesters fix only works provided you leave the unit unpowered for several seconds before powering up again, since the 47u doesn't discharge enough via the diode to allow immediate reset.
Also, when a PT goes into latch up once it will usually do it again even when the pin 6 resistor is more than 1k (something inside seems to burn out and it can't drive as much current at start up any more). You usually have to make it several k after that to avoid further latch ups, which explains why increasing R21 helped.
« Last Edit: July 31, 2011, 05:42:35 PM by merlinb »
tuckster
« Reply #706 on: August 03, 2011, 03:23:19 PM »
Just finished my little angel (birthday edition). The effect works butit is very subtle like Pigyboy noticed first. Any suggestions on this?
askwho69
« Reply #707 on: August 04, 2011, 06:40:30 AM »
wonderful layout! mine sharing ? i like on board stuff
 :D
"To live is to die"
tuckster
« Reply #708 on: August 04, 2011, 07:05:29 AM »
Yes od course but I don't know if there are any mistakes in it. Just wanted to wait until someone found out whats the problem with the new circuit :D I only steal circuits, unfortunately I'm not able to fix designes by myself.
Pigyboy
« Reply #709 on: August 09, 2011, 10:42:43 AM »
Made a little discovery. All my angels always turn on without latching with the depth knob maxed. Any ideas?
                                                            - FANG
~arph
« Reply #710 on: August 09, 2011, 10:48:13 AM »
A quick question.. if it latches, does it make a terrible noise?
Could be that I'm latching up one of my builds when the modulation gets out of hand or the input signal gets too high (too much feedback)
EDIT: I'm not talking about a LA
Pigyboy
« Reply #711 on: August 09, 2011, 11:07:48 AM »
What are you referring to? When my angels latch they just sound a little different without the effect....and they get hot!
                                                            - FANG
~arph
« Reply #712 on: August 09, 2011, 11:16:08 AM »
Cool, that's the anwser I was looking for..  I was talking about a very noisy stuck oscillation kinda problem. Now I think of it.. I think I had a similar sounding issue with my belton reverb brick.. if the input level got too high it went into horrible oscillating noise.
Sorry for the interruption, please do continue...
askwho69
« Reply #713 on: August 09, 2011, 02:28:06 PM »
so the one knob cheap chorus needs to be look?
"To live is to die"
rhcp_schipper
« Reply #714 on: August 11, 2011, 11:34:33 AM »
Hello Everybody,
My name is Tim and Chris from el musico loco introduced me to this forum. I bought one of the Angel choruses he sells. Unfortunately the one I have has the latching problem described above. I found out that when the depth knob is maxed out and you put the power on the angel will work fine(every-time you do that). But when I have my favorite setting (both knobs approximately  at 12 o'clock), the angel will latch up.
I have allot of contact with Chris about this problem, but he said to me it is smart to post the problem here at the forum so maybe one of you guys could help us out here.
The first thing I'm going to do is putting a new PT2399 in, because maybe this is a bad chip, who knows?
Many thanks!
Tim
Govmnt_Lacky
« Reply #715 on: August 11, 2011, 11:55:22 AM »
...I found out that when the depth knob is maxed out and you put the power on the angel will work fine(every-time you do that). But when I have my favorite setting (both knobs approximately  at 12 o'clock), the angel will latch up.
Has anyone bothered to probe Pin 2 of the PT to see what resistance/voltage range it falls into when it is working/latching?
for an amount of ‘up to and including my life.’
Pigyboy
« Reply #716 on: August 11, 2011, 12:10:16 PM »
Welcome aboard Tim!  How often is it latching?
I have one here that seems to start chorusing when I plug a 12volt adapter into it and keep chorusing when I swap it right over to a 9 volt...
                                                            - FANG
rhcp_schipper
« Reply #717 on: August 11, 2011, 12:22:47 PM »
Mine keeps latching every time I put power on it, with my own settings! Even when I power it up at 12 volts the angel latches!
The only way to make it chorus is to max out the depth knob, and than put the power on. There is no other way.
Pigyboy
« Reply #718 on: August 11, 2011, 02:00:20 PM »
After you power it on with the depth maxed then it works normally?
                                                            - FANG
rhcp_schipper
« Reply #719 on: August 11, 2011, 03:02:45 PM »
Yes! But when I dial in my own favorite setting, and power it off and back on again, it latches! So each time I power up the Angel I have to max out the depth knob, and than bring the power on to get it working properly! After I've done this I can dial in my own settings and use it.
