loves_guitar
Quote from: azrael on October 13, 2009, 07:01:28 PM
What do you use for decal softener?
Microscale Industries Inc.: "Micro Sol"
Got it at the same little hobby store I got the decal paper from.
Gorgeous etch on that Banana fuzz!!! Love the colours on the sides (very fitting with the name). Watched your explanation video. Can't wait for the demos!!
Slade
#10781
Here's the video demo at last!
~arph
Nice demo! sounds very cool and versatile.
It does seem that you need a gain recovery stage after the tone control, because as you change tone and diodes you need to crank up the volume to the max, but other then that very nice!
Slade
That's a good idea. I think I'll give it a try.
Thanks for your comments!
leeranya
Quote from: loves_guitar on October 13, 2009, 01:44:44 PM
Thanks everyone for the kind words! Seriously, I am blown away by the talent in this place, so to you have guys compliment my work carries a lot of weight. Thanks!
I'll try and answer everyone's question with describing my workflow (and no, I'm not a graphic designer - more of a 'graphic-designer-as-a-hobby!'):
1) Sand the enclosure starting with 150 grit. Continue sanding with finer and finer grit. Then sand with steelwool going from coarse to fine.
2) Wash box with water and dish soap.
3) A shot of primer (using Rustoleum). Let dry overnight.
4) Apply spray paint (mostly have been using Rustoleum - have also tried automotive spraypaint from the automotive aisle which works good, but pricey and Testors model spraypaint). Spray once in the morning before work and once in the evening. Typically about 4 coats. Just until the box has good coverage, watching specifically for the edges.
5) Once happy with paint, let dry for 3 days before applying clearcoat.
6) Once I'm happy with the design in Photoshop and I know it will line up with the holes, print off waterslide decal (been using Testors clear decals). I usually do this during the 3 days I'm waiting for the box to fully dry.
7) Clearcoat decal paper with 3-4 coats.
8 ) Apply decal. Once dry, apply decal softener. Then once dry again, cut out holes and give it some more decal softener around the holes.
9) Clearcoat box. Typically 6 coats. Wet sand (under a running tap) with 2000 grit automotive sandpaper after the first 3 coats. Nothing the final 3 coats.
10) After it's dry (typically leave it overnight), grab my "Mother's Carwax" and wax and buff the box.
11) Grab a drink and enjoy!
Hopefully that explains everything. If anyone has any questions, feel free to fire me a PM. You can also check out my blog for future progress.
does the decal cover the entire top of the enclosure (being a single big decal), or does it cover specifically the areas around the text, so, it's divided into smaller pieces of decals, one per text (gain, volume, pedal name etc.)?
rousejeremy
Quote from: Slade on October 13, 2009, 09:15:27 PM
My last pedal, the Banana Fuzz!!
Check out the features in this video!
Soon I'll upload a video demo.
Regards,
Fernando.-
Nice layout. I really dig your gear demos on Youtube as well. Keep up the good work.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
loves_guitar
Quote from: leeranya on October 14, 2009, 10:53:18 AM
Yes, it's a full face decal. Both on the top and on the sides. I tried at first just cutting around the image (for example the guitar or amp for the input and output), but I could never feather the edges of the decal enough that you couldn't see it. So now I cut out the decal the size of the surface face (the top or the sides). That way the edges of the decal get lost in the edges of the actual pedal.
Crazyyellowfox
I wasn't sure how I was going to go about labeling these PPP boxes, but suddenly, I was inspired by
Freekmagnet's Funky Popsicle graphics.
I drew the kangaroo on the tremolo. These were experimental, I'll probably put a little more effort
into future graphics, but I think I like this method a lot!
ianmgull
Brymus
Quote from: ianmgull on October 15, 2009, 12:19:41 AM
Rebote 2.5:
I really like the Art work on this one !!!!!! Amazing :icon_cool:
Magnus
#10790
Hello together,
really great pedals again - especially the etched enclousures  :icon_eek:
Here is the next one, my "Rectifier IN A BOX" (Dr. Boogey)
i built from an own layout based on the 4thlevelmedia-layout:
(Click to load larger images)
Greetings from Germany
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
Slade
That's a pretty nice building, Magnus. I like how you wired the trimmers. It's not necessary to use the 3 wires though, you can do it just with the two that comes from different pads.
Excellent wiring!
Renegadrian
TRIBUTE DOD 308 YJM with mods
The DOD 308 is the pedal that got me into DIY - I received one for my 2k7 birthday (2 years ago, in november) and I wanted to add a LED, make it true bypass, etc...I always thought I'd build one from scratch sooner or later, but other projects always came first, so only now I finally built one!!! But this one had to be special!!! So I went with a great pic of the man, add diodes switch (how I love the LEDs clipping!) and the LED border...Here is the result...
edd101
Quote from: Renegadrian on October 16, 2009, 07:11:20 AM
Adriano, your pedal is looking cool and the led border adds that little something ;) I personaly like the sound of 308 very much because I used to have one and which was very close to my heart!
...it is always funny until someone gets hurt!!!
ShortScaleMike
oliphaunt
Insanekane
Little Black Wonder  :D
noelgrassy
Quote from: Insanekane on October 17, 2009, 05:30:37 AM
Wholly Poop-inna-Pita Pocket pal! You nailed this one too. The filigrees the vines almost resemble
the engraving work one can have done on a firearm or edged weapon. That's at $1,000+ per
square inch! Your lines are not only deep but they retain their crisp edge everywhere I look. Did
you go through a lot of R & D to find this perfect resist method. I must try etching a box before I'm
so old and feeble that I eventually put my eye out while picking my nose. :icon_idea:
Great looking product by the way,
NG.
"Of the demonstrably wise there are but two: those who commit suicide, and those who keep their reasoning faculties atrophied by drink." Mark TwGL
solderman
#10798
Quote from: AudioMime on October 12, 2009, 12:18:16 PM
Quote from: Fuzz Aldryn on October 12, 2009, 07:20:05 AM
Hi,
seems to me that I started there a little flame war which I didn't intended to start. The already posted layiout over there is wrong an way too big. That's why I started to make my own one using the gutshots posted there. If the pros over there give their ok to post it, I will do it. Until then I won't post it anywhere, I'm sorry.
@Lucian: Sorry, but I soldered the PCB directly onto the switch so that I would have to desolder it to make some pic of the components side. Didn't make any before I built i together.
Regards
Helge
It's all good man.  I found the thread
PS:
http://www.youtube.com/watch?v=_QyYaPWasos     (nsfw)
I must say that I'm a bit surprised by the pics from the guts of the commercial Heliotrope by Catalinbread. It willl probably last but...
seems to me that a lot of folks around here makes  higher quality stuff than those pic shows. And they sell them on the open market  :o.
Probably that's just me having too high thoughts of commercial box manufacturing  ???
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Taylor
Quote from: solderman on October 17, 2009, 06:29:14 PM]
Try searching for "Schumann lion" at the other forum and see if you can hold down your lunch. I'm not normally snarky about build cleanliness, but seeing gut shots of some of the most sought-after boutique boxes makes you realize that, what is important to us doesn't really matter to most players.
