mills
punkin
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
mills
mongo
Ok, better pictures of my Salad bowl fuzz with the plexi bottom!
flo
That Salad bowl fuzz is beautiful! It's like Dalek's pet.  :o 8)
How did you cut the plexi into a nice circle?
How did you attach the bottom place to the metal bowl?
mongo
I attached the bottom drilling small holes and putting some L shaoed little metal plates.
adf
Hi everyone, thought i'd finally share some of mine...
Orange squeezer...
and EA Tremolo.
a few smudges but im pretty pleased with them ;D
Al
kurtlives
Push pull tone switch for a clear bell like tone or a more bassy heavy, gainer tone.
My DIY site:
www.pdfelectronics.com
ralley
Latest build, it's my take on a BOR: Combined BSIAB2 and SHO in a box - hence the name, Mar-sho-ll.  Strangely my SHO no longer crackles, it used to but stopped, still works fine though.  Artwork was done by taking swatches from photos of actual Marshall amps and assembling them in Inkscape, this was then printed out on a colour laser and stuck down with PVA glue and then clear coat applied over the top.  Unfortunately the texture on the grill cloth etc. got a bit lost, the white specs are just surface dust.  Might try and source some actual Marshall knobs to complete the effect.
Still battling to get my holes drilled exactly where I want - and this was with centre punching and a drill press - buying a vice for my press now.
Rob.
Sender lawyers, guns and money
The sh*t has hit the fan.
   - Warren Zevon
Renegadrian
Chris, your Fender-ish pedal is gorgeous!!! So nice and classy...And we got another "amp-like" pedal, nice!
And adf, your pedals are so nice to see...A real good introduction, a first post couldn't be better than that!!!
The French connection
Still hot from the iron...
...and the guts for those who are a bit ''voyeur''
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Ell
Hey everyone, I'm new here and have almost finished looking at all of your pedals (I'm on page 391 of this thread) and felt that I should add my own.
Here is my first one, a passive A/B box
And my Orange Squeezer which I finished an hour ago. Some of you helped me out with it so thanks, I really can't believe it's working. I used Torchy's layout, it's a shame that I can't find any more of his.
kurtlives
Quote from: Renegadrian on February 15, 2009, 05:56:21 PM
Thanks for the compliment, really appreciate it!
My DIY site:
kurtlives
Quote from: The French connection on February 15, 2009, 06:54:57 PM
Dan
Nice pedal Dan, liking the vero are you ;)
Just curious is to why you mount the vero upside down? Also how do you secure it?
My DIY site:
Quote from: kurtlives on February 15, 2009, 08:55:28 PM
Dan
Thanks! Your Prof Tweed looks great too. I like the push/pull switch tone pot idea.
I mount the board inside the enclosure and wire the pots before, so i found it's easier to solder on the board when it is upside down. All the wire are bend at near 90 degrees and of equal length (height) so the board can't move and it's laying (suspended) just near the edge so i put a foam in the cover and everything's fine...i think. I don't know if it's clear, i'm not so good in english.
Dan
My picture files:
cloudscapes
just a minimalist TS clone with a coupla mods (extra diode here, dfferent cap there)
{DIY blog}
{www.dronecloud.org}
DavidRavenMoon
Makore is commonly called African Cherry, which is why I thought that was what you had there.  It's redder than maple.
I have some nice curly Makore veneer that looks just like that.
Lacewood (silky oak) is just one of those woods I never cared for, along with Wenge.
Quote from: John Lyons on February 12, 2009, 11:28:12 AM
David
The first pic is a curly maple top.
Makore is kind of like Mahogany but you can
get some quilted and mottled grain that is very dramatic
and has a lot of depth.
Lacewood/buttonwood is very dramatic, when you turn it a little
that heavy grain pattern changes and it looks more like
a solid wood grain.
John
SGD Lutherie
Hand wound pickups, and electronics.
www.sgd-lutherie.com
www.myspace.com/davidschwab
kurtlives
Quote from: The French connection on February 15, 2009, 10:47:14 PM
Dan
Dan
That made perfect sense your english is fine. Do you use solid gauge wire or stranded to help support the board?
My DIY site:
frank_p
Quote from: kurtlives on February 15, 2009, 11:13:22 PM
Dan
Dan
You could put an other pull-push pot for opening the negative feedkack loop, I like mine without it sometimes.  Nice !
tehfunk
My second materialized build... a Fulltone OCD. I did a really simple three coats of glossy black rustoleum paint without primer, just sanding, just to see how it would turn out. But, on that note, the pedal sounds pretty damn good.
Carvin CT6M > diystompboxes.com > JCM800 4010
The tools of the artist give you a chance to twist and bend the laws of nature and to cut-up and reshape the fabric of reality - John Frusciante
